The Ford Barn
-   -   neat little alternators (https://www.fordbarn.com/forum/showthread.php?t=99440)
jambottle 03-04-2013 12:03 PM
3 Attachment(s)
picked these up at Webster.Figered they would fit easily in stock generator case.might even be able to attach a fan?was told they are kobota fork lift units.easy to hide,low on banger.
4dFord/SC 03-04-2013 12:46 PM
Re: neat little alternators
They may not get enough cooling installed inside a generator case. I believe that's the reason that Ed Whitney makes his own cases and you only have to send him the front and back plates off your generator.
V8COOPMAN 03-04-2013 01:00 PM
That alternator is most-likely only rated at 14 Amps. DD
rotorwrench 03-04-2013 02:06 PM
A fork lift generally only has a rudimentary electrical system. They just need to charge the battery for the next start. It looks similar to some I've seen that replace a generator on an old Harley motorcycle.
