The Ford Barn
-   -   Engine swap (https://www.fordbarn.com/forum/showthread.php?t=94165)
Gino 01-09-2013 06:53 PM
Engine swap
Hi, I want to Pull the existing engine from my 30" coupe and install a temporary engine ( life is not good if I'm not driving my A" ) is it easier to pull both the engine and transmission as one piece and then reinstall in one piece? I hope you get what I mean. Thanks a lot Gino.
Vanspeed 01-09-2013 06:58 PM
Re: Engine swap
I always install in one piece but that is just me.
Mitch//pa 01-09-2013 07:04 PM
Re: Engine swap
i split them less work
A31Woody 01-09-2013 07:08 PM
Re: Engine swap
I split them when I did it. I see no reason to remove the transmission if there is nothing wrong with it.
Maclab58 01-09-2013 07:21 PM
Re: Engine swap
I split mine also.
TinCup 01-09-2013 07:52 PM
Re: Engine swap
If I am just changing engine I just pull the motor. Reconnecting the ujoint clamshell takes as long or longer than swapping the motors. I only pull the transmission if I am unsure of it or the u-joints condition.
Tom Wesenberg 01-09-2013 09:49 PM
Re: Engine swap
Engine only with me also.
Fred K-OR 01-09-2013 10:01 PM
Re: Engine swap
The limited times I have done this sort of things, I have pulled both at one time.
Milton 01-09-2013 11:33 PM
Re: Engine swap
Split!
BashawT 01-09-2013 11:47 PM
Re: Engine swap
Unless you're doing work to both I'd split
Logan 01-10-2013 02:11 AM
Re: Engine swap
Split forsure. It's hard enough getting the motor in between the stock motor mounts. Muchless while trying to put the transmission with the drive shaft at the same time.
ctlikon0712 01-10-2013 05:59 AM
Re: Engine swap
Yes the last time I did it I did it as one unit, I had a engine tilter. I wished I had just pulled the motor. Logan and the others are right, its just easier not dealing with the u-joint, even with the clutch issue.
Vanspeed 01-10-2013 11:35 AM
Re: Engine swap
really guys? I had my engine and trans out and the new engine and trans back in in less than an hour. Maybe it's because I am younger.:)
Logan 01-10-2013 11:40 AM
Re: Engine swap
I'm 19 and have done countless engine swaps and the couple different shops I've worked at. You got lucky with yours, especially of you have stock motor mounts. I've had to use frame spreaders, and porta-power hydraulic jacks meant for body work to spread the frame rails. Then also take out one motor mount to get the motor into place. Then drive the other motor mount back into place with a 3 pound sledge. And thankfully I didn't have to do that while installing the tranny at the same time.
bill44 01-10-2013 02:12 PM
Re: Engine swap
I just did a split. Takes a few hours, less if you have help.
Dave in MN 01-10-2013 05:05 PM
Re: Engine swap
I install about 1-2 engines a month with the engines I rebuild. I prefer to split. I don't know what it is about repacking the U-joint with grease but I hate it! I don't go there if I don't have to. Now maybe if my wife would have bought me one of those cool cordless grease guns instead of a new shirt and tie for Christmas I'd change my mind...she didn't so...again, I would split it!
Good Day!
ps: I'm not complaining...the shirt and tie look good but a cordless grease gun could look better.
Tom Wesenberg 01-10-2013 07:39 PM
Re: Engine swap
"ps: I'm not complaining...the shirt and tie look good but a cordless grease gun could look better."
Dave, I'm using the cordless grease gun that came with my car when it was sold new! :D
CarlG 01-10-2013 08:01 PM
Re: Engine swap
1 Attachment(s)
Not cordless, but works great!
green30coupe 01-10-2013 08:14 PM
Re: Engine swap
I'm with Tom. All my grease guns are cordless!:D
Ed
Domino 01-10-2013 09:32 PM
Re: Engine swap
split
