The Ford Barn
-   -   grease in radiator (https://www.fordbarn.com/forum/showthread.php?t=91423)
rogerkb1936 12-09-2012 08:47 PM
grease in radiator
i removed the top of radiator and found it nearly totally plugged with grease., other wise fine. i rodded it out carefully and got the bulk out. but of course there is more still sticking to tubes. soooo, what is the best cleaner to remove the residue? thanx, roger
Tom Wesenberg 12-09-2012 08:55 PM
Re: grease in radiator
I've heard Cascade is good to use. I'd probably use gasoline.
To rod it out you'd have to have the radiator off and the tank or tanks removed. Seems like it should be clean after this.:confused:
Barry B./ Ma. 12-10-2012 07:58 AM
I used Lestoil in mine, it is oil based and does a good job disolving grease. I ran a bottle in the radiator for a couple days then flushed it with water.
pat in Santa Cruz 12-10-2012 09:51 AM
I have also heard Cascade has satisfied several owners, though I have not tried it. I have used TSP tri sodium phosphate (the real TSP, not the substitute that seems to be more common) and it worked well.
Keith True 12-10-2012 10:42 AM
I use lestoil in the A's for the most part.I just put a reman engine for a fellow,he had a greasy radiator so I poured in some simple green.After a week the inside of everything looked spotless.The grease broke down enough to be held in suspension,it all went out through the petcock.When I worked on Macks we used cascade when we had an oil cooler failure.I worked on Cummins at another place,they used okite in them.They also used it to clean the floors there.The lestoil always left a smell behind me as I drove,I didn't care,it was behind me.It made a lather,the simple green didn't.That was my first try with that stuff.
Jim Brierley 12-10-2012 01:27 PM
I use about a cup of Simple Green, run it for a few miles, drain and repeat if necessary. The grease likely came from lubing the water pump. You may need to do this once a years of so?
