The Ford Barn
-   -   Repro Spring Shackle Bushings (https://www.fordbarn.com/forum/showthread.php?t=91267)
dmaxweb 12-08-2012 02:40 PM
I bought some spring shackle bushings from Brattons and the ID is larger than the worn ones on there now. The wall of the repro bushings is thinnner. I have NOS shackles and they are a sloppy fit with the repro bushings. Does anyone have some NOS bushings to mic the OD & ID?
Aerocraft 12-08-2012 02:56 PM
Re: Repro Spring Shackle Bushings
Try www.a-springs.com They have brand new springs and bushings that are excellent quality.
Gar Williams
dmaxweb 12-08-2012 03:05 PM
Gar Williams
Bronze bushings at $14/pair - :eek:
Tom Endy 12-08-2012 03:14 PM
I would suggest you give Walt Bratton a call, 800-255-1929. Ask to speak with Walt. He would want to hear about this and will certainly take steps to resolve the issue. He may have some recent stock from a supplier that is not correct. I have been buying rear shackle bushings from Bratton's for years and have never had a problem with them.
If you are talking about the front shackles, I had a similar issure. Apparently there is more than one version of the Model A front shackle perch. What I did was buy a number of rear shackle bushings from Bratton's and had a friend cut the length down on his lathe.
On the front ends I have restored the shortened rear shackles fit the front correctly.
Tom Endy
dmaxweb 12-08-2012 03:38 PM
Tom Endy
It's the front shackles.
Other than length, is there a difference between front and rear?
dmaxweb 12-08-2012 05:12 PM
Does anyone have any NOS bushings they are willing to part with?
Tom Endy 12-08-2012 07:52 PM
On the several front ends I have restored I found that the shackle bushings were the same, except the fronts are shorter than the rears, I bought about a dozen rear shackle bushings from Bratton's and had them shortened by a friend who has a lathe.
Tom Endy
