Question ,, chassis difference and worth I have a question regarding the difference between a 1928 and 1931 chassis as well as a cost/worth of a well rusted 1928 chassis[ right hand e-brake, engine turns over, steering and wheels don't] with a rotten front spring mount, rear radius arms and missing steering box..
Re: Question ,, chassis difference and worth I guess I'm also asking how hard it is to mount a 31 body on a 28 frame..
Re: Question ,, chassis difference and worth The piece that will stop you is the front cross member. The radiator mounts are higher on the 28-29 to suit the shorter radiator. If you mount a 30-31 radiator on the earlier chassis, it will sit higher than the rest of the body.
Re: Question ,, chassis difference and worth Front crossmember as mentioned above and possibly with some 31 bodies the cowl mounting hole locations are different. I am sure someone that is more familure with those changes will chime in. Depending on the condition of the front crossmember with the solid motor mount someone may trade you straight across for a usable 30-31 front crossmember. If I remember correctly there was a slight change in rivit locations some time during production that may make this change alittle more work. Rod
Re: Question ,, chassis difference and worth I just paid $600 for a chassis that sounds a lot like yours, but with a few more usefull parts. I think I paid too much by about $200, but I am hoping the engine will run, which would make me feel better, and I like to tinker. Deep pits in frames and other componants make this heavy iron in my eyes, and worth scrap rate. Hate to be a Debbie-downer, but it is what it is.
Re: Question ,, chassis difference and worth OK, thanks fellas.. I'm glad I asked this question again because I had forgotten about the differences.. I think I'll pass on this thing and keep looking..
