The Ford Barn
-   -   Grease seal installation (https://www.fordbarn.com/forum/showthread.php?t=86209)
BrianBurkert 10-15-2012 03:55 PM
In the case of the grease seals for the rear hubs, driveshaft, and axles... for modern seals, which direction does the taper go? I'm confused by what I read, and the new seals are not the same as the original leather seals, so my Ford literature is not helping.
Mitch//pa 10-15-2012 04:16 PM
Re: Grease seal installation
the spring in the seal goes towards the fluid / oil.
BrianBurkert 10-16-2012 10:01 AM
Thanks. I should know this by now but I always need affirmation when I work on a rear axle.
