The Ford Barn
-   -   Riddle my rivets! (https://www.fordbarn.com/forum/showthread.php?t=85190)
lance leblanc 10-05-2012 02:23 PM
Riddle my rivets!
As a new comer to Ford Barn I want to Thank all the folks who share their knowlegde and experience on these forums.
"Without it I believe I would have never garnered the courage to begin the frame off restoration of my father-in-laws '29 Tudor".
So to my question, I wish to replace the rusted cowl panels that are below the fuel tank and are riveted to the firewall.
Where do I begin?
How much do I need to be concerned with the stability and alinement of the firewall? (will it take care of itself)
What rivet tools are recommended, do I need a air tool?
What size rivets?
Should I be losing sleep at night of this?
Lance
Carter 10-05-2012 04:07 PM
Re: Riddle my rivets!
If I am not mistaken, the cowl panels are spot welded to the firewall. The only rivets would be the 3 on each side under the bottom where that flange rivets to the subframe connector.
The cowl lacing rivets would go along there, but they don't hold the panels together.
wrndln 10-05-2012 04:16 PM
If the cowl isn't that badly rusted out, I would simply install a patch in the rusted area. It is that hard to do, much easier, I think, than trying to install a repro panel that may or may NOT fit correctly - note the emphasis on NOT. I have installed several cowl patches and it is not that hard.
Rusty Nelson
lance leblanc 10-08-2012 02:59 PM
The panel is only rusted the botton 4 inches so I have concedered a patch, but with out the use of a welder and wanting to do as much myself as posible,
the entire panel seemed the way to go. However if these are spot welds that I am looking at and not rivets then that changes things.
Elcastor 10-08-2012 07:22 PM
Take it to a guy that can weld in a replacement piece of sheet metal. It is a job for a welder, and it should not cost too much to get it done right. Prefabricated patch panels just do not seem to work that well. (This is what I recommend anyway, others may disagree!)
Mitch//pa 10-08-2012 07:25 PM
just get the bottom patch panels thats a common spot for rust out.
