1934 Tudor and Fordor Roof Compatibility Hello, I am looking for some info, I have a 34 tudor that someone tried to braze a solid top into. the problem is they warped it really bad. I have located a gentleman who has a couple of tops but he isnt sure if they are Tudor or Fordor. I can take measurements from mine but it would be easier if they are the same or if the one is better than the other I want to get the best one. . Thanks Ian
Re: 1934 Tudor and Fordor Roof Compatibility If you look in the 33-34 book from the early V8 club it has the body dimensions in.Lawrie
Re: 1934 Tudor and Fordor Roof Compatibility Thanks but I dont have the book, guess I will order it.
Re: 1934 Tudor and Fordor Roof Compatibility Not the same . Just looked at the book Lawrie mentioned . The wood rib kits are different . Pretty sure the tack strips are a different pt # also . I have the back half of a 34 2d body that has good upper stuff if that is of any help .
