51-53 Autotransmission rebuild? Even in the Portland OR area, I can't find a shop that can remember how to rebuild a '53 automatic! Any suggestions for a local solution? The reverse band has no material left and the drum is scored. Thanks Newc
Re: 51-53 Autotransmission rebuild? Talk to Leo at Master Transmission on Lombard St. in St. Johns. If he is not available, look elsewhere.
Re: 51-53 Autotransmission rebuild? Might check with Gene Benson at Flat-O-Products in Salem. He does the C-4 to a flathead adaption and has been in the transmission business for a long time. He may be able to do it or know someone who can. You might also check with Dale Matthews at Memory Lane Motors on Holgate Ave. Dale sells a lot of early Ford V-8's and may have someone he uses to make repairs on them.
Re: 51-53 Autotransmission rebuild? Canby transmission on 99 in Canby,OR did exceloent work on my 51 Mercamatic.
Les Bliss |
Re: 51-53 Autotransmission rebuild? Thanks to all the local fellows; Newc
