The Ford Barn
-   -   Rear gravel deflector 6a-17808 (https://www.fordbarn.com/forum/showthread.php?t=79203)
335Bill 08-08-2012 08:59 AM
Hi, new to the forum here. I am looking for the rear gravel deflector for a 48 coupe, and I need the center piece only. Help me out here?
Fred A 08-10-2012 11:50 AM
Posted in Wrong Section!
Since you have no location listed we don't know were you are anyway. Good Luck: Fred A
dick lyons 08-10-2012 03:43 PM
Re: Rear gravel deflector 6a-17808
my 48 coupe is one piece.
Bob G/Spanaway 08-10-2012 04:00 PM
My '48 is three.
FLA48 08-10-2012 07:54 PM
My '48 also has 3.
47Merc 08-11-2012 06:35 AM
C & G have them listed
https://secure435.hostgator.com/~dlv...3&g=297&t=1832
al pa. 08-17-2012 08:52 PM
Didn't look to see who sold the three piece,I have on my 47 merc.I installed the center piece first,and it looked good.The end pieces,did not match the fender contour,unless I moved them away from the center.This left a gap of about 1/2 inch between the center piece,and end pieces.I cut pieces of plastic trim,from home depot,1/2 inch thick,cut to length,carved and sanded to the top shape of the pan,marked for bolt the holes,and drilled.I had to paint with light coats to keep from affecting the plastic,but they almost look as they belong there.I may be the only person with a 5 piece gravel pan. :rolleyes:
