The Ford Barn
-   -   2-Position 35/36 brakes... (https://www.fordbarn.com/forum/showthread.php?t=7862)
Enbloc 07-14-2010 01:52 PM
Has anyone messed around with the two different positions in the brake cross shaft that connects to the brake pedal?
One position is ment to give a soft pedal and the other firm.
Which is which? Which do you prefer and why? Experiences?
Thanks
FlatheadTed 07-14-2010 04:34 PM
Re: 2-Position 35/36 brakes...
The upper hole is for more leverage ,but you pedal will travel farther.The lower one gives less pedal travel less leverage and is recommended with Floaters ,Ted
