The Ford Barn
-   -   wiring insturment panel (https://www.fordbarn.com/forum/showthread.php?t=76688)
poolnut 07-11-2012 02:59 PM
Help im new to this I just bought a 29 pickup roadster It does need a little work I am not much of a mechanic so please help me out Is it much trouble to take out the instrument panel I would like to put new gauges in And are they hard or complicated to wire up
msmaron 07-11-2012 03:05 PM
Re: wiring insturment panel
You have 4 screws, 2 on top and 2 under the panel, just remove them and take out the panel and slowly unscrew all your connections and MARK THEM as to know where to place them back
That should do it
Mitch//pa 07-11-2012 03:12 PM
also disconnect your battery before you start
disconnect ///unscrew the speedometer cable once you pull the dash foward a little
CarlG 07-11-2012 03:25 PM
The only "gauges" that are in the panel is the ammeter and the speedometer. The fuel level gauge is integral with the fuel tank and does not come out with the panel.
