The Ford Barn
-   Model-A (https://www.fordbarn.com/forum/forumdisplay.php?f=8)
-   -   Av8 Chassis with new Flathead and Buick finned Brakes (https://www.fordbarn.com/forum/showthread.php?t=74459)
tahern 06-18-2012 02:53 PM
City: florence
State: ky
Price: 3000
6 Attachment(s)
Nice Model A Av8 chassis, all the hard work is done. Comes as seen without the body!! Has split wishbones, F1 cross member, and pedals, rebuilt 37 ford top loader with new clutch, pressure plate and throw out bearing. Has a 21 stud 1936 flathead. Motor is completely rebuilt consisting of: motor has been mangafluxed for cracks, bored with new pistons, rods reconditioned, crank turned with new bearings, new oil pump, Isky cam and adjustable lifters, new valves and hardened seats, heads are aluminum and have been redone, distributor has been redone with new caps, button, coil and wires. Comes with an aluminum intake with a ford 94 carb. This motor has not been fired since rebuild, still can see the assembly lube. Comes with 1935 wire rims and tires, also have a complete buick finned brake setup for the front just bolt it on and go already adapted to ford axle. Comes with radiator and radiator shell.As I said all the hard work is done. Please feel free to call if you want to see, or if you have questions. Thanks Terry 513-807-4488 also will ship at buyers exspence.
tahern 06-20-2012 06:31 PM
Re: Av8 Chassis with new Flathead and Buick finned Brakes
Bttt 2800 I keep the tires and rims
tahern 06-23-2012 11:56 AM
2000 for the motor and trans
tahern 06-25-2012 04:47 PM
Sold!!!!
