The Ford Barn
-   -   Model B Crankshaft Specs (https://www.fordbarn.com/forum/showthread.php?t=7260)
Tony Cavotta 07-07-2010 07:23 PM
I need some help can someone tell me the origional size of the Model B 4 cylinder crankshaft journal and rod bearing size
James Rogers 07-07-2010 08:00 PM
Re: Model B Crankshaft Specs
Stock
Mains are 1.999
Rods are 1.874
alfonso 12-30-2016 11:40 AM
Hello to the whole Ford Barn group.
I need a Model B crankshaft, because mine is out of order, does anyone know who can supply me, please.
Thank you in advance from Spain.
Greetings Alfonso.
Tom Wesenberg 12-30-2016 01:42 PM
Greetings Alfonso.
Try Bert's in Denver. 800-321-1931 but that number probably won't work from Spain. Try email: [email protected]
Juggler 12-30-2016 03:46 PM
Hello Alfonso
Closer to home, try Belcher Engineering in UK
Gary's Spanish probably isn't up to much, but he will have what you need and ships worldwide
http://www.belcherengineering.co.uk/
Cheers
Juggs
Synchro909 12-30-2016 03:50 PM
I have an early one - no counterweights. It has standard sized journals but freight to Spain would probably be expensive.
alfonso 12-30-2016 06:07 PM
Originally Posted by Juggler (Post 1406749)
Hello Alfonso
Cheers
Juggs
Hello Juggs:
I am very grateful for your quick response, I have already sent an email, translated into English, thanks to Mr. Google, I just wait for the answer.
Happy new year, best regards:
Alfonso.
Juggler 12-30-2016 07:10 PM
You are very welcome
Let us know how you get on. My father and I run B engines in three of our Model A's. All English, made in Dagenham.
Post some pics of yours when you get time.
And Feliz aņo nuevo to you too!
alfonso 01-02-2017 05:35 AM
Hello Juggs:
I have not received a response from Gary, these are bad dates, I will wait.
My car is a 1930 roadster, bought in 2015, had V8 hydraulics brakes, in very bad condition, I renewed them completely, the gearbox is also B, and the gears went out, I repaired the selector, and I was only able Make 1,700 km before the connecting rod breakdown.
Taking advantage of the breakdown, I have it disassembled to paint, so it is not in the best moments for photographs.
I am happy that your A model, with a B-motor, works properly, have you lengthened the development of the transmission?
I'll let you know about the progress on my car.
Best regards, Alfonso.
alfonso 01-02-2017 05:52 AM
Thanks Tom, I've already sent you an email, asking if you have one.
Happy year 2017, Greetings Alfonso.
alfonso 01-02-2017 05:56 AM
Thanks Syncro 909, indeed, the cost of shipping from Australia must be expensive.
Happy year 2107, greetings Alfonso
Juggler 01-04-2017 04:12 PM
Originally Posted by alfonso (Post 1407890)
Hello Juggs:
No, all stock transmission and torque tube. Used stock A flywheel housing and an English AAE oil pan (which does not have the shroud on it) that was original to an English AA truck.
If you need help and guidance on fitting a B motor in an A then a search on here will provide the answers, or I'd recommend Jim Brierley's book which has chapter and verse
http://i1114.photobucket.com/albums/...ies/Banger.jpg
Best
Juggs
