The Ford Barn
-   -   Can someone ID this early wiper motor & I need a arm (https://www.fordbarn.com/forum/showthread.php?t=67938)
no6 04-09-2012 07:21 PM
5 Attachment(s)
This wiper motor fits my model A coupe windshield holes but it needs spaced out about 3/8". I don't know what it is off of and I also need a arm and blade. the shaft is tapered, splined and has a 10/32 threads. On the bottom is E A Laboratories Inc. Brooklin NY. One other question, it is 6V do I need a reducer on the motor to run 12v, thanks.
DBF 30 04-09-2012 09:06 PM
Re: Can someone ID this early wiper motor & I need a arm
Hi, It is an E.A. Labratories wiper that was for a time period installed at the factory. I have one with a brass cover and the output shaft on mine is about two inches longer than yours. Different model?
I am no expert, still new to the model a. I found most of my information on http://www.modelawipers.com/. He also sells arm and blades. Check out the website and you can probably get more detailed info.
Hope this helps.
Fred 04-09-2012 09:30 PM
That IS NOT an original Factory installed wiper on any Model A Ford...
Rowdy 04-09-2012 09:41 PM
Fred is correct on that, not an original. I was told by Phil at bert's these were actually used on the early Jeeps, but were a popular replacement for the A wiper motors. I have had several of them over the course of time. They seem very durable as most that I have found work. Unfortunalely the potmeatal likes to crack at the ears like the originals. Rod
no6 04-10-2012 09:38 AM
btt
DBF 30 04-10-2012 04:11 PM
I stand corrected. I was going on the information posted on ModelAwiper.com. On the home page, bottom right hand corner it states that Ford started installing E.A. Labratories wipers in March 1929.
Thanks for the correction.
BILL WILLIAMSON 04-10-2012 07:26 PM
no6,
The shaft looks much like Datsun in the '60's. Read somewhere, I think, that some V.W. arms fit on the Jeep wiper motor?? Bill W.
Tom Wesenberg 04-10-2012 08:58 PM
Same company, but a different style was used during Model A production.
no6 04-14-2012 07:03 AM
Still trying to find a arm.
Paul in Colorado 04-14-2012 09:22 AM
I found one at Bert's.
no6 04-14-2012 01:23 PM
Thanks I will check that out
