oil pan drain plug I tried heating up the solder around the spinning drain plug threads,but it did not take. It did loosen the old drain plug and I was able to get it out. What kind of solder should I use to try and reseal the threads? Thanks
Re: oil pan drain plug Regular solder is all that is needed The trick here is cleanliness of the metals to be soldered and good flux. It also could be brazed.
Re: oil pan drain plug Use a good flux after cleaning all oil away and, if you can get it, 50/50 lead/tin solder. A plumbing supply house has it in 1# rolls and possibly smaller rolls. Tell them what you are using it for and never use it on your household plumbing system.
Re: oil pan drain plug I just ran into this problem last weekend. I took the pan off and cleaned everything up really good and then TIG welded the thread insert back in. It won't ever come out again!!!
Re: oil pan drain plug Jake Don't strip any threads now.
Re: oil pan drain plug IMO Ruby fluid flux and 63/37 solder is the way to go. Make sure you get it hot enough but not so hot you burn the flux.
