The Ford Barn
-   -   Small bit of antifreeze on head ?? (https://www.fordbarn.com/forum/showthread.php?t=65986)
C26Pinelake 03-21-2012 08:51 PM
I noticed when taking my car out of storage that over the winter there is a small amount of antifreeze ( about size of a nickle ) at one of the head bolts. Should I wait to see if it gets worse or what should I do now. Should I be concerned ?
Thanks wayne
bogdonj 03-21-2012 08:55 PM
Re: Small bit of antifreeze on head ??
I would re torque the head and see if that helps. Make sure you use the recommended sequence and tighten to 55 ftpounds Is it a newer engine or hasn't been touched?
Colorado Greg 03-21-2012 08:59 PM
What is the level of antifreeze like in the radiator? How much fluid has leaked out?
I would re-torque the head, change the oil to see if there's any water in the oil, pull the plugs and spin the engine by hand to make sure the cylinders aren't full of water. Guess it all depends upon how much fluid has been lost.
heneste 03-22-2012 02:50 PM
Definitely re-torque the head.
When I had my motor rebuilt, during the first few hours of running one or two of the head bolts had weeping up the threads. It was explained to me that antifreeze will leak easier than plain water and that once the corrosion builds up, the weeping should stop.
With the outside temperatures changing quite alot, you could also have the nuts or head bolts changing size slightly and causing small clearances.
If not, you could try a thread sealer and re-torque the head.
steve s 03-22-2012 04:22 PM
That happened to me once with a new rebuild. The rebuilder suggested lowering the coolant, removing the nut, put a dab of blue silicone around the hole, retorque nut.
It worked, but I have no idea how good an idea it is otherwise. Surely, the silicone must mess with the torque readings. Also, if you go this route, do it all in one session; don't let the engine sit with one stud unbuttoned.
Steve
