rear wheel safety catches Does anyone know anything about safety catches for the old Fords so rear wheel won't come all the way off in case an axle breaks. Thanks Rick
Re: rear wheel safety catches Yes - Speedway used to carry them. I have a set I bought from them, but only used a very short time.
They attach using the bolts for the wheel cylinder. If I still have them and you want a set, you can have them for the cost of shipping |
Re: rear wheel safety catches I am using a set from Speedway. My advice is to not use the bolts that came with the set. Use studs with washers and a nut on the outside. It sure makes life easier if you have to work on your brakes etc.
Re: rear wheel safety catches Vern Tardel makes them, speedaway copied them.....but they don't work with the lincoln brakes.
http://www.verntardel.com/collection...-drum-retainer |
Re: rear wheel safety catches Paul, thanks for the offer I would like to use them now that I am working on the car and thanks to all that responded. Rick
Re: rear wheel safety catches I have the Speedway retainers on my 46 coupe. I really had to grind on them to get them to not rub on the drum.
Matt |
Re: rear wheel safety catches I use them on our '39 CS and '47 Convert.:) I'd like to put them on our '39 LZ. Does anyone make them for Lincoln Zephyrs, or will we have to fabricate something?:confused:
Re: rear wheel safety catches Quote:
Re: rear wheel safety catches Ken, I remember seeing those also. Can't remember where, but it was a while ago. Please post the info. if you find it. Thanks, JIM
Re: rear wheel safety catches Ken thanks. I hope you can find (and post) a picture, I'd like to see it. I’ve got the rear out of the Zephyr so, if I can find something to effectively provide a level of safety, now would be a good time to install it. Vic
Re: rear wheel safety catches I think these are the alternate type that are being talked about.
http://www.vintageford.com/Products/01475.jpg 01475 SAFETY HUB ADAPTORS-REAR 1928-48 1928-48. Temporarily holds the axle, hub and wheel in place if the axle were to fail. Set of 2 for the left and right sides of the rear housing. Comes with lock rings and hardware. Lock rings need to be welded in place after installation. Hub not included. 211A P. 422 These are on Sacremento Vintage Fords website. |
Re: rear wheel safety catches Thanks Enbloc. Do you know how they actually fit on the car? If you happen to find a photo of those installed on a car or explain how they are installed please post it also. I wonder if they somehow fit where the stock Ford grease retainer is. What are those long 'pins" for? Thanks, JIM
Re: rear wheel safety catches Thanks Enbolc, I've got the same questions as 19Fordy. Vic
Re: rear wheel safety catches Here's a iink to the Speedway Brake Drum Retainers: http://www.speedwaymotors.com/Early-...iner,1981.html
Had to grind them a bit to fit on my '40, too. Fortunately, have not yet had an opportunity to test them. |
Re: rear wheel safety catches Thanks for the photo Enbloc. Those are the ones I'm talking about . Who sells them? Like Vic I need them for my ZePhyr
Re: rear wheel safety catches The large casting slids over the bearing housing inside the drum. The small steel ring is then welded to the bearing housing in the appropriate place. The casting is now trapped on the hub by the welded ring.
Two of the studs are threaded into the casting and protrude towards the backing plate. Two of the backing plate bolts are removed and the studs will now take their place in the axle casing. What you end up with is the casting "floating" around the hub. If the axle was to break and start to move it would be stopped by the ring hitting the floating casting which itself is fixed permantly to the axle casing. When fitted you would have to undo and remove the nuts on the studs that are attached to the axle housing if you wanted to remove the hub as normal. |
http://www.vintageford.com/sect_sear...y=Axle-%20Rear |
Re: rear wheel safety catches Enbloc, Thank you very much for all the helpful details. That looks like something I would like to try making, (wish I had a lathe) just for the personal satisfaction of doing so. If anyone buys a set and installs them, please take an post photos of the step-by-step process. Thanks again to all those folks who conributed to this thread. JIM
