36 gas mileage what are you guys getting for gas mileage in your 35,36's with a stock motor and 411 gears? i am getting 9 mpg. i would like to increase the mpg
thanks, Brendan:confused: |
Re: 36 gas mileage oh a anouther question, i have a 35 motor that has flat top pistons, and heads for domed top pistons , would this have something to do with it?
Re: 36 gas mileage I get 12-14 on a Strom 48 carb same car with 3.78 RE. Either you drive it real hard or you need a carb rebuild job.Your also lowering your stock compression ratio by using domed heads with flat top pistons.ken ct.
Re: 36 gas mileage i drive real easy. would lower compression have something to do with it? also i plan on rebuilding the carb that is next on my list
Re: 36 gas mileage WOW 9mpg, Brendan I have '36 with 4.11's and I need to check my MPG too. My motor is a 59AB with a single 97 on top.
H36 |
Re: 36 gas mileage I caution both of you to buy a good Quality kit USA made and have the proper tools to do the job. ken ct.
Re: 36 gas mileage Ken ct any kits that you can recommend ? I also wanted to look into more efficient air cleaners or just swapping out a paper filter for my air cleaner, it's not a oil bath, it's a SOS pad looking material. I washed it and sprayed some oil on it but I know it's not efficient.
Re: 36 gas mileage i just got a Kand N air filter for my pickup. when i first started it it, i could tell their was a difference in the way it ran. the weather has been not to good hear so my pickup has not been out for about 2 weeks. Ken i got a Stromberg kit from Baxter Ford parts
Re: 36 gas mileage Lowering already low compression probably isn't helping your mileage . That said I'd start with the carb to see if it is jetted too rich or if there are other issues there . Distributors not working properly can really hurt mileage also . Air filter issues ? You should be getting better than 9 MPG if all is right .
Re: 36 gas mileage i went to the Stromberg site, i see that there are different power valves. What size power valve and jets would i need for my stock 35 motor ? also i have seen adjustable jets, are they any good?
Re: 36 gas mileage Brendan ,This 35 with a 411 differential gets about 15 m.p.g.. This 35 with a 378 gets closer to 17 m.p.g. Very disappointed in 15 m.p.g. and figure its time for some adjustments. Both motors have good compression. Good luck with your pickup. You have rebuilt the engine so there has to be an easy solution. I swear radial tires helped my m.p.g. a bit.
Re: 36 gas mileage i would be vary happy with 15 mpg. with gas at 4.39 a gal hear in Santa Rosa i figure i need to do something.
Re: 36 gas mileage 35+36 usually have diff strombergs on them,i would call Baxter ford parts for a recomendation. ken ct.
Re: 36 gas mileage any time you lower compression you lose power, which means you use more fuel to move your car the same distance as a higher powered engine, and unless your in real hilly country i would go to a 3:78 rear end
Re: 36 gas mileage Quote:
Re: 36 gas mileage Brendan,
If mileage is primo and you aren't using a Stromberg 97 find one and rebuild it...your motor will hardly know the difference if at all. I'd start with 45 jets and #65 power valve....standard for a 97. Baxter has good stuff so the kit will probably suffice. The hidden culprit in a Stromberg is the power valve....they leak all to often. For free I'll check your PV in a simple fixture I have. Yep new ones leak about the same percent of the time used ones do. I sure agree with the compression thing....you're killing yourself. Heads for flat top pistons are like dog poop, they are everywhere. Think about trading yours for the right ones. Charlie ny [email protected] |
I was clear as mud on the carb....the 97 will not adversely effect the performance of your car but it will cause an increase in fuel economy. Since you are on the right coast you might get ahold of Max Musgrove in Utah...fyi he builds Strombergs 100 at a time and is THE guy who breathed life into the English 97's. Charlie ny |
Re: 36 gas mileage Brendan, visit the Ford Green Bible chapter 5 pg 431 rebuild kit #'s it show's confirmation as Charlie stated jet's #45's, 36-38 90hp. Charlie and KenCt are 2 of the best in carb rebuilds, as you know I had Kenct do mine and it's smooth. I also agree with the proper heads and flat piston will be less air space leading to better compression. I know u know many folk your way so wouldn't be to hard to chase some down, if you don't already have them.
Re: 36 gas mileage Get the correct heads for flat top pistons & switch to 3.78 or even 3.54 gears & your mileage will improve.By the way,I wish our gas was as cheap as yours!
Re: 36 gas mileage Present price here in S ct. is at least today is $3.89 reg.for Hess up the street. ken ct.
