1930 a how to remove rearglass with out breaking it 1 Attachment(s)
hello
i am taking my 30 tudor apart to repaint it what is the best way to remove the rear glass with out breaking it thank you kevin |
Re: 1930 a how to remove rearglass with out breaking it take off the molding of course and then from the OUTSIDE using a sharp razor knife score through the rubber gasket. Go inside the car and do the same and you should be able to just pop the glass out a that point with no problem. Remove of course from the inside of the car.
Re: 1930 a how to remove rearglass with out breaking it Have somebody inside the car to catch it as you push it out from the outside.
Don't forget to replace it with safety glass! Doug |
Re: 1930 a how to remove rearglass with out breaking it Kevin, the only thing holding your rear glass in is the trim moulding on the inside. Once remove, you should be able to push the glass in with the rubber gasket intact. Replace the gasket and the glass with safety glass.
Re: 1930 a how to remove rearglass with out breaking it Be sure to do as Doug says and have someone inside.... I said bye bye to my original rear window because I didn't ask the wife for help.
