The Ford Barn
-   -   Brake Fluids (https://www.fordbarn.com/forum/showthread.php?t=64316)
FLA48 03-05-2012 01:46 PM
Brake Fluids
After replacing the clutch on my 48, I bled the brakes, A few weeks later I again bled the brakes. Yesterday I noticed a partial container of synthetic brake fluid next to the empty container of regular brake fluid. If I indeed added the synthetic to the existing non-synthetic brake fluid, did I create a problem?
Mart 03-05-2012 02:11 PM
Re: Brake Fluids
Hello and welcome to the ford barn.
By synthetic, do you mean silicone??
Do the cans have dot numbers on them?
If you mixed silicone and regular type, that might be a problem.
Mart.
Old Henry 03-05-2012 02:19 PM
Re: Brake Fluids
Any "synthetic" brake fluid can be mixed since it is all synthetic except silicone - DOT 5 brake fluid can not be mixed with any other. So, if by "synthetic" you actually mean "silicone - DOT 5" you'll need to replace it all. Otherwise, you're OK.
FLA48 03-05-2012 03:19 PM
Re: Brake Fluids
It is Preston Synthetic DOT 3, so I guess I lucked out.
Thanks
Mart 03-05-2012 04:25 PM
Re: Brake Fluids
I had some experience testing clutch slave cylinders, and they were failing early. I had used dot 3 fluid. I used dot 4 fluid and they went through the test cycle ok. If and when I buy fluid I always pay the extra for the dot 4.
Mart.
rickmass 03-06-2012 10:09 AM
Re: Brake Fluids
can you use dot 3 on fords and chevy,s.Rickmass
TomO 03-06-2012 11:27 AM
Re: Brake Fluids
Dot 3 is the standard brake fluid that has been in use since the 1930's. It can be used in any Ford or C***.
rickmass 03-06-2012 12:13 PM
Re: Brake Fluids
Thank,s Tom for the come back..Rick
