29 coupe window crank handles install? so i just got a 29 coupe and am in process of replacing billet with original style stuff...i bought window handles from c w moss and the pins to secure but my posts on car are square with a slit cut not a round hole...any body help me with install....cw moss tech line ...couldnt get through to them on 3 attempts....any help and or pics will help
Re: 29 coupe window crank handles install? The square with the slit is correct. Did you get the wrong handles? Factory handles have a square hole with a set bolt.
Re: 29 coupe window crank handles install? im not sure if i got right handles ordered handles for 5 window coupe from cw moss the handles were vintiques theres no thread in handles ....may be ill thread then n use set screw
Re: 29 coupe window crank handles install? do you have another supplier that may have better or correct handles?
Re: 29 coupe window crank handles install? I got mine from Snyders.
Re: 29 coupe window crank handles install? If u tape them your self,be sure to already have the set screws your going to use,try not to use fine thread=dose not hold as well;)
Re: 29 coupe window crank handles install? Quote:
Got mine from Brattons. Pluck |
