The Ford Barn
-   -   Direction of Running Board to Fender Carriage Bolts (https://www.fordbarn.com/forum/showthread.php?t=63298)
Hunter 02-25-2012 01:25 PM
On a 29 coupe, are the bolt heads inside the running boards, or do they get inserted through the fenders first so that the heads of the bolt are in the fender wells?
I have seen this disussed before but could not find it using the search engine.
Thanks - Hunter
31Tudor 02-25-2012 05:47 PM
Re: Direction of Running Board to Fender Carriage Bolts
The head of the bolt would be on the fender side with the lw and nut on the running board side.
msmaron 02-25-2012 06:00 PM
1 Attachment(s)
does this help
Tom Wesenberg 02-25-2012 06:12 PM
As Mark pictured, the heads face the REAR on both ends of the running boards. It doesn't seem right to be this way on the front, but it is. I doubled checked my 28 Phaeton just to be sure.
31Tudor 02-26-2012 01:16 AM
Oops sorry Hunter, 28 through Sept 30 the bolt head faced inward as was corrected by Marc and Tom. October 30 through 31 the bolt head faced outward.
