The Ford Barn
-   -   Aamco Brake Shoe Grinder (https://www.fordbarn.com/forum/showthread.php?t=62767)
CA Victoria 02-20-2012 06:15 PM
I need help setting up an Aamco show grinder. I have the drum size set and have the drum calipers to measure the drums with but cannot determine how to compensate for the various drum sizes at the machine. Thanks in advance.
Bill in NJ 02-20-2012 06:25 PM
Re: Aamco Brake Shoe Grinder
What model AAMCO do you have ??
CA Victoria 02-20-2012 07:29 PM
Re: Ammco Brake Shoe Grinder
1 Attachment(s)
It is an Ammco 8000.
I have the rough size set for 11" and the dial indicator set at zero. The screw shaft with the red handle moves forward and back to place the shoe.
BUBBAS IGNITION 02-20-2012 08:22 PM
Tim
Set the machine for the 11 inch shoes and the dial at zero. Then turn the dial in to amount of oversize ( above the 11 inch) that the drum was cut.
You have to be pretty exact on the drum sizing..
CA Victoria 02-20-2012 11:21 PM
Thanks Ford Barners. Several quick responses and my questions have been answered.
Don/WI 02-21-2012 12:32 AM
Originally Posted by BUBBAS IGNITION (Post 369208)
Tim
Remember that you should grind a maximum of 0.005" at a time. This is stated in the instructions for Ammco Brake Shoe grinders as I have found out thanks to a few of the Ford Barners that sent me instructions. Don/WI
ctlikon0712 02-21-2012 01:23 AM
Here is the manual for it on Ebay for $20
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Bill in NJ 02-21-2012 04:18 PM
I remember you saying the drums were turned to .060 ?? Not sure if they are safe with out putting the metal bands on them before you had them turned. Better ask on this site to be safe
ctlikon0712 02-21-2012 07:23 PM
I would Heat the rings, freeze the drums and the rings should drop right on without pressing and running the chance of damage. Then turn them with the rings on.
Bill in NJ 03-06-2012 06:51 PM
So how did you make out fixing the machine ??
d.j. moordigian 03-07-2012 07:37 PM
After seeing this thread I thought I would dig the one I have out for a quick
restore, and you know how that always goes. I have a 880, which looks very
close to Tim's. Anybody know what the difference is between the 800, 880
and the 8000?
Dudley
Kevin in NJ 03-07-2012 10:35 PM
I have the manuals in digital format for the 890 and the 8000 which I will email to real addresses.
I have one of the 800 series grinders, I do not remember the number, and it uses a drum sandpaper. I have a barrett brake doktor so I do not use the Ammco grinder.
The 890 and 8000 use a sheet of paper that is clamped into the drum.
ctlikon0712 03-08-2012 01:18 AM
Kevin i sent you a PM. Thanks
fordhistory 04-25-2015 09:02 AM
Kevin,
Could you send me a copy of your brake shoe grinder instructions. Thanks so much.
Henry Dominguez
[email protected]
