The Ford Barn
-   -   Rear roller brake tracks (https://www.fordbarn.com/forum/showthread.php?t=60515)
Richard/Ca 01-29-2012 07:40 PM
I thought I would try and save some money. I took the roller tracks off the rear backing plates to see if I could save by having a friend weld them. Question does anyone know what the spec. or what the dimension the tracks were weld and ground to? Are they the same as the front? Because I brought a set of them. Thank for any advice.:confused:
wrndln 01-29-2012 07:57 PM
Re: Rear roller brake tracks
The tracks where the wear is should have a flat area where the roller pins didn't cause any wear. You just need to leave a little of the original flat area when building up the worn part and file down the weld even with the non-worn part. That is what I did.
Rusty Nelson
Pilotdave 01-29-2012 08:50 PM
The front and rear dimensions are different. The dimension is the distance between the rivet pin and the top surface of the track. Rear is 1" and front is 1 5/16".
Rich in Tucson 01-30-2012 09:29 AM
Make a rectangular gauge (of metal or very hard plastic, etc.) that is 1" wide for the fronts and 1 5/16" for the rear and long enough to cover both track sides; about 1/8" thick or so. Then have tracks welded in place, grind to fit with gauge. Flame harden if desired.
Richard/Ca 01-30-2012 02:02 PM
Pilotdave
Rich in Tucson
tracks you very much for your advice. I am kind of afraid to say that one of you has it back wards. It won't be hard to figure out with the measurement that you gave me anyway.So a big thanks to all of you. Richard/Ca
