The Ford Barn
-   -   Mystery coil? (https://www.fordbarn.com/forum/showthread.php?t=57873)
Craig Lewis 01-02-2012 09:35 PM
Mystery coil?
3 Attachment(s)
While checking some parts today with the J.Std revisions ....I found this slant-poil coil.
Shape & dimensions appear to be your classic Model A coil, except the manufacture's mark MC isn't listed in my book. Does anyone recognize that logo?
Craig Lewis 01-03-2012 12:14 AM
Re: Mystery coil?
Wow, Magnito Corp. Who'd a thunk it.
...thanks Vince.
I suppose judging this coil (restored) on a fine point car, would carry an almost certain loss of points
...anybody?
Steve Plucker 01-03-2012 12:53 AM
Re: Mystery coil?
Is it workable Craig?
Great find. Maybe used in Canada???
Pluck
Craig Lewis 01-03-2012 01:14 AM
Re: Mystery coil?
Untested. I do both US and Canadian swap meets & haven't the foggiest idea where I picked it up.
Say...who's got a fast easy way to bench test this thing?
Tom Wesenberg 01-03-2012 01:41 AM
Re: Mystery coil?
Chances are that it works. So far of all the coils I've picked up and tested the only one that didn't work was the one with a large bullet hole through the middle of it, and even that one worked for a few seconds when I first checked it.
Connect a condenser across the two primary terminals. Then connect a battery across the two primary teminals. Hold the coil wire 1/4" from either primary terminal while you touch one of the battery wires on and off the primary terminal. You should get a hot blue spark each time you take the battery wire off the terminal.
Marco Tahtaras 01-03-2012 01:44 AM
Re: Mystery coil?
Note that the twin lines on the left side of the circle is open at the bottom forming (loosely) an "A" and the right side closed forming a "B" making it American Bosch Magneto Corp. That is normal. There should be a two digit date code on the bracket (likely containing an "8"). Please let me know what it is.
Thanks...
Ron in Quincy 01-03-2012 02:59 AM
Re: Mystery coil?
Marco,
My Bosch, slant pole, coil is stamped "8", with a space, then "9" .
Ron
Craig Lewis 01-03-2012 07:26 PM
Re: Mystery coil?
3 Attachment(s)
I tested the Magneto Corp coil (as per Tom's instructions) and it makes a good spark. In fact it's the best of 6 coils tested.
Unfortunately there's no date codes.
WRONG
I just found the code! Hopefully the photos shows it.
