Seeking NOS '53 Ford Rear Wheel Bearings. It's time. Found one side was dry and noisy. It's time.
The part number is 8A-1225. They're normally sold with the retaining ring, 8A-1144. I need two sets. All leads to reliable sources will surely be appreciated. |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. They are not NOS but the last time I got them at NAPA. They have the gasket also.
PN--PGB88128R |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. Richard, have you tried Joblot in NY? The phone # is: 718-468-8585. Vic
Re: Seeking NOS '53 Ford Rear Wheel Bearings. Quote:
Don't get me started. But thanks. |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. I would think that any of the major bearing and seal industrial supply operations would have them. You probably have one or two in your local area, like Kaman Induatrial, or Applied Industrial. they usually carry every bearing known to be used in the U.S.A.
But thanks. |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. "It's time. Found one side was dry and noisy".
Richard, you said you have plenty of time. Does that mean you are driving the car now? Try Stacy Brown in Texas |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. Richard,the part number changed to A9AZ-1225-A FROM 8A-1225-A.I have one 8A-1225-A AND SEVEN OF THE A9AZ-1225-A in stock if you can't find them where you
are. John Kelley B&L Ford Ashland,Pa. 570-875-4417 |
Re: Seeking NOS '53 Ford Rear Wheel Bearings. According to the Internet, Antique Auto Supply (Stacy Brown) has 30 of the 8A-1225 part numbers, 14 of the 8A-1225-A part numbers, and 4 of the A9AZ-1225-A part numbers.
Re: Seeking NOS '53 Ford Rear Wheel Bearings. Green Auto Sales deals primarily in NOS Ford parts.
Their online inventory shows a few of the bearings in stock - link: http://www.greensalescompany.com/GreenSalesInventory.asp |
FOUND! --- NOS '53 Ford Rear Wheel Bearings. Thanks to all who helped.
I found NOS bearings at a place called Miller Obsolete Parts. Nice knowledgeable guy named Mark. Excellent prices. A comfortable small company. www.millerobsoleteparts.net Happy New Year! |
