35-40 Spring Shackle shaft position Is there an angle that the square part on the spring shackle shaft goes in the rear axel housing and spring? Thanks Dave/Green Bay
Re: 35-40 Spring Shackle shaft position once pressed into the spring, the inner shaft with square part can be rotated to fit the shackle bars
