Pressurized Oil Tank Does anyone out there have some ideas for a pressurized oil tank for lubing a new engine. Had an engine built and bench run back in August and just about ready to start it off in the car. The oil was drained before given to me and the engine has been sealed up since then. Don't want to spin a bearing waiting for oil pressure to build up.
Re: Pressurized Oil Tank How about using one of those air operated barrell pumps and attaching the output line where the oil pressure sending unit or the oil filter feed line goes? Used to pre-lube large diesel's this way and it was easy and worked quite well. FWIW
Re: Pressurized Oil Tank Scott
I made one using an old 5 gal propane tank. I added a guage and valve and tubing with a fitting to the oil pressure spot on the block. It worked real well, but later I talked to a guy who used a new $19.95 tank sprayer with a line setup to the engine. Added 4 qts or whatever, pumped it up and did the job Jim |
Re: Pressurized Oil Tank Thanks for the input. Is that a garden style tank sprayer you are talking about?
Re: Pressurized Oil Tank Yes
Re: Pressurized Oil Tank Made mine from an old fire extinguisher really simple with a regulator and a gauge. Can give pic's if wanted.
R |
Re: Pressurized Oil Tank One could make one using a by pass type oil filter cannister...
Karl |
Re: Pressurized Oil Tank 1 Attachment(s)
here's a 'oil pump priming shaft'
for Mopar's http://www.summitracing.com/parts/DCC-4286800/?rtype=10 are they not available for your engine? |
Re: Pressurized Oil Tank scott
doesn't look like there's shaft for flatheads or a lot of people don't know about it here's link to oil priming http://www.btc-bci.com/~billben/flathead.htm left side under 'engine' then 'oil priming' looks like pressurizing it is! |
Re: Pressurized Oil Tank I made one using a piece of large diameter copper pipe with end caps soldered to each end. Attaches to port on back of block. Has pressure gauge, fill plug and tire valve stem at top. I think it holds two quarts. Easy to make and works very well. Can add or send pictures if you would like to see.
Re: Pressurized Oil Tank Could it be because the oil pump drive is a little hard to access on "a lot of flatheads", and the "shaft" that drives them is "kinda weird and lumpy shaped"?
Re: Pressurized Oil Tank Pump has no shaft direct gear drive.
R |
Re: Pressurized Oil Tank If your engine was rebuilt using pre-lube on all the bearings and has run after assembly there should be plenty of oil in the bearings for you to start it without causing any damage. Pressure should build in a couple of seconds. However, to be sure you can prime the system by removing the sender and with a small funnel pour in a half cup of oil. I have a 5" pipe nipple standpipe that keeps the sender up above the firewall for easy access. Keep things simple. John
http://i174.photobucket.com/albums/w...s/IMG_0486.jpg |
Re: Pressurized Oil Tank Ronnie, If your comment was for me, I was joking. Camshaft is hard to access and is kinda lumpy.
Re: Pressurized Oil Tank Quote:
Re: Pressurized Oil Tank Doesn't everybody have a Chevy oil pump lying around? I submerged one in a coffee can of oil; plumbed the output to a tee at the gauge port (with a gauge in the other side of the tee) using plastic tubing and some fittings out of my junk box. Spun the oil pump with a 1/4" drill and turned the engine with a socket wrench. Did this with the oil pan off so I could see where the oil was dripping from.
Re: Pressurized Oil Tank oldford2>>>However, to be sure you can prime the system by removing the sender and with a small funnel pour in a half cup of oil. I have a 5" pipe nipple standpipe that keeps the sender up above the firewall for easy access. Keep things simple.>>>
I agree, John. A simple funnel and gravity work fine, no elaborate pressurizing needed. I slowly added 5 qts this way before startup on a complete rebuild. Instant pressure on cranking indicated with a guage setup exactly like yours. Jack E/NJ |
Re: Pressurized Oil Tank get one of those cheap suction guns they use for sucking out the filter housings .pull plunger all the way back fill with moter oil. put fiting on end of hose with a 1/4 pipe thread. screw into oil pressure sender taping push lever till it bottoms out eng is primed & now you have a tool that has maney uses .good for cleaning filter housing adding trans oil or diff oil
Re: Pressurized Oil Tank If you build an engine with everything pre-lubed (white grease and cam lube) and you take the plugs out and spin the thing until you have oil pressure showing why is any of this necessary? I'm just asking to learn things to make my engine building technique better, not to be facetious.
Re: Pressurized Oil Tank Hey Lou
The idea is to make sure all the oil galleys are full. Something you really can't do with assy lube. Some guys will also turn the engine over with a wrench while the oil is being pumped in to ensure all rods, etc., are taken care of Jim |
