The Ford Barn
-   -   would you run this head (https://www.fordbarn.com/forum/showthread.php?t=52748)
elwood 11-10-2011 08:57 AM
2 Attachment(s)
hey guys will this cause hot spotting and pre ignition ?
would you run this ?
alanwoodieman 11-10-2011 09:04 AM
Re: would you run this head
NO would not
David J 11-10-2011 09:15 AM
I've seen worse used . The pitted chamber will cc a little more than the others but once it carbons up that won't be as much of an issue . Are these rare or something ? Why not replace it ? Anyways you have a judgement call on your hands here . I personally would throw it out but I have plenty heads .
f1builder 11-10-2011 10:52 AM
i don't see a performance issue with using them.
Gumpy 11-10-2011 10:56 AM
Yes
richard crow 11-10-2011 11:02 AM
if you are runing a stock eng it will run fine
JWL 11-10-2011 11:04 AM
You will never know what it looks like when in operation. It looks like it might be an EAB head and won't be a problem.
Kube 11-10-2011 11:09 AM
Originally Posted by alanwoodieman (Post 304036)
NO would not
Neither would I.
Brian 11-10-2011 11:21 AM
Looks like they've been planed a massive amount. Check the piston and valve to head clearance. Probably find there is contact and they'll need to be clearanced anyway. Then you'll want to find some better candidates. Brian
alanwoodieman 11-10-2011 12:51 PM
what heads are they? EAB-8RT-8CM-? I have a few extra on the shelf if you need one.
elwood 11-10-2011 12:54 PM
there EAB heads, and yes i could use one alan,
Russ/40 11-10-2011 01:40 PM
Running it you would never know the difference. But, as easy as heads are to find, I'd replace it. JMHO
alanwoodieman 11-13-2011 10:50 PM
finally got to the parts barn today, don't have any EAB, just a couple of 8BA pass side, I 8RT drivers side, and a bunch of A heads, including one that is suppossed to be for a 42 "A" engine. Sorry
Walt Dupont--Me. 11-14-2011 08:36 AM
Elwood, the area above the pistons look pretty small, I'll bet the pistons will hit the heads. Walt
elwood 11-14-2011 01:20 PM
2 Attachment(s)
Hi Walt, these are the heads that came off this engine, its all EAB, I even found a EAB stamp on the crank.
Iv still got the heads off my 8CM, so iv cleaned them up and am gonna run them on this engine.
Im gonna put the cam Pete ground for me in it also, and plan on claying it all for clearance checks.
Thanks for the input, I always like hearing from you.
Walt Dupont--Me. 11-14-2011 01:54 PM
Those Merc heads are awfull big. I'd use the EAB,s if I could. Walt
elwood 11-14-2011 08:21 PM
would you use them pitted up EAB headsWalt ?
look at the pictures again please, that one combustion chamber is ugly.
elwood 11-14-2011 08:24 PM
could i get the 8CM heads milled 30 or 40 thousands ? to lower the cc,s and raise compression
jack orchard 11-14-2011 08:34 PM
just wondering-what the difference is between EAB and 8CM in cubic centimeters. how much lower would the compression ratio be?
