The Ford Barn
-   -   Flathead Engine Bore??? (https://www.fordbarn.com/forum/showthread.php?t=52193)
CC33 11-04-2011 08:39 AM
Is 60 over the max bore for a flathead?
Ed Pitts 11-04-2011 08:48 AM
Re: Flathead Engine Bore???
Which block do you have?
flathead4rd 11-04-2011 09:10 AM
On an 8-BA block you can go to 3-3/8" if you have it sonic tested first. Most go to
3-5/16" to be safe. On the 59 blocks I'm not sure of the max bore.
CC33 11-04-2011 09:27 AM
It's a '36 LB.
JM 35 Sedan 11-04-2011 09:31 AM
some say to be on the safe side .060" is max for the early 21 stud blocks. I've only ever gone .030" over on mine so I'm not sure. I know some have taken a '37 block to .080 over but that year block may have thicker cylinder walls.
Ed Pitts 11-04-2011 09:39 AM
Here is a previous discussion on the issue that you have. Ed
http://fordbarn.com/forum/showthread...light=max+bore
