The Ford Barn
-   -   V8 identifying (https://www.fordbarn.com/forum/showthread.php?t=51571)
jkeesey 10-27-2011 03:40 PM
V8 identifying
im sure everyone but me knows how, but how do i identify my flathead v8? i was told its a 1939 but its missing water pumps, starter, and everything on top so i cant compare it to any others that way.
Charlie Stephens 10-27-2011 03:55 PM
Re: V8 identifying
Identification of the early flatheads is best approached in terms of the block. There is an unbelievable amount of interchangeability for the accessories over the years. Count the number of head studs.
1) If there are 17 studs it is a V8 60 used in vehicles between 1937 and 1940. This engine was also used in the French built Simca in the sixties but I don’t know what occurred between these two periods. Look for casting numbers and stamped steel water jackets in the side of the block. Post what you find and someone can probably further identify the engine.
2) If there are 21 studs the block was built 1932 to 1938. The transition to 24 studs was late in 1938. Check the water petcocks on the front of the block next to where the lower hose from the radiator enters either an inlet fitting (1936 and earlier) or the water pump (1937 and later). It the petcocks point straight down it is a 1932 block. If the block is not a 1932 next look for a vent from the crankcase area out through the front corner of the oil pan. If there is no vent the block is 1933-34. If there is a vent it is 1935 or later. As a matter of interest, the 1936 engines were the first to use insert bearings. Both insert and babbitt bearings were used throughout 1936. The insert bearing engines can be identified by LB cast at the top of the left front face of the block or by the letters LB stamped into the surface where the intake manifold attaches. Some engines were not stamped and in other cases people tried to inflate the price of their blocks by stamping LB into them when they were sold. Be careful. Now check for the location of the water pumps. If the water pumps mount on the block the engine is 1937 or later. All engines beginning in 1937 were inserts. Frequently you will encounter a 1937 block with factory block off plates held on by two bolts over the water pump passage at the front of the block as it was common for Ford dealers to install this engine as a replacement in the earlier cars. Of course there will be slight transition periods at model change over with the older blocks usually going into the commercial vehicles. There may be subtle differences between the 1933-34 and the 1935-36 engines but I am knowledgeable enough about these years to know what they are. The casting numbers on the flywheel housing will also help identify the exact year of the engine. Post what you find and someone can probably further identify the engine.
3) If there are 24 studs the engine was produced between late 1938 and 1953 (1954 in Canada). If the distributor is mounted on the front of the block the engine is late 1938 through 1948 (1947 for trucks). If the distributor comes up at an angle and appears more like a modern distributor it is a 1949 (1948 for truck) through 1953 (1954 in Canada). The casting numbers on the flywheel housing will further identify the exact year of the engine. Post what you find and someone can probably further identify the engine.
4) There are a lot of additional foreign and industrial applications of these engines but the preceding covers the domestic US automobile production.
Charlie Stephens
jkeesey 10-27-2011 04:26 PM
Re: V8 identifying
Its definitly not a v8 60 I can id them pretty quick. It has 24 stud heads and lower rad hose water pumps. It also has the dist mount flush with the frot of the engine, not 49-53. The only numbers I could find on it was a #5 on the right front intake mount surface and 61948 on the left side between the head and where the intake goes
flatjack9 10-27-2011 05:24 PM
Re: V8 identifying
If a pencil will rest on the flange above the distributor, it is 39 to 42. 46 to 48 would have 59 cast on the bellhousing. 39 - 41 have core plugs in the pan rail, 2 per side.
jkeesey 10-27-2011 05:49 PM
Re: V8 identifying
I didn't find anything on the belhousing besides some nice blue paint from a few decades ago. I believe a pencil may rest above the dist flat, it seemed to have a small shelf
rotorwrench 10-27-2011 06:10 PM
Re: V8 identifying
Here is a good thread to look at for ID. It has pictures of most engines.
https://www.fordbarn.com/forum/showth...ngine+pictures
Kerby
Joe KCMO 10-27-2011 06:33 PM
Re: V8 identifying
Having worked on many 39's, there are several indicators:
1) 2 core plugs on each side of the pan rail. From the outside 2 bumps on the side of the block just above the oil pan gasket on the block.
2) To distinguish from 38, the crank shaft is longer.
3) To distinguish from 40, pressed on cam gear. 40 and on bolt on.
4) 41 last year for the bumps, no core plugs.
5) 45 - 48 have a 59 on the bell.
You can get all this on an excellent thread which describes all the rest including these if you use the search feature.
JM 35 Sedan 10-27-2011 07:01 PM
Re: V8 identifying
Can you put up a few pictures here? Top, bottom, sides, back. That would allow us to see exactly what you have and pin it down to a year or a range of years that it was manufactured.
jkeesey 10-28-2011 09:34 PM
Re: V8 identifying
Cleaned the block to prepare for pictures ad found bright yellow paint on the left side reading PASSENGER ONLY, so I'm assuming this was a ford replacement engine. I'm thinking its a 41 but I'm gonna post some pics tomorrow and see if anyone can verify
