The Ford Barn
-   -   front cross member (https://www.fordbarn.com/forum/showthread.php?t=50501)
aaron griffey 10-16-2011 11:20 AM
front cross member
Is the front cross member of the frame the same for all years of Model A?
gweilbaker 10-16-2011 11:31 AM
Re: front cross member
No, mainly 28/29, 30/31 due to radiator mounting height, as always, there are more minutia details.
GW
Purdy Swoft 10-16-2011 11:45 AM
The 28 front crossmembers have different placement for some of the rivet holes and will be a problem to fit the later frames
aaron griffey 10-16-2011 12:45 PM
Thanks folks.
So how can I tell the early from the late?
I need one for a '30.
Fred 10-16-2011 12:48 PM
In 1928 there were several different typs...
Purdy Swoft 10-16-2011 01:58 PM
The 28 crossmember that I referr to has ears with holes that bolt to the engine and is the solid front motor mount style. I'm not sure what month of 28 but at some point it was recommended that the ears be sawed off and that the yoke style front motor mount be used. I think this was performed at the dealership. The 28 front crossmember had a bit higher pad where the radiator mounted with a round hole instead of a slot on each side where the radiator bolts on. These crossmembers can be confusing to the untrained eye if the early motor mounting ears have been sawed off. If you need a used crossmember call Berts 800-321-1931 and tell them what you need it to fit. good luck.
aaron griffey 10-16-2011 05:52 PM
Bert's does not have one for a '30. Thanks to all who have posted on this subject.
I've been around model A cars and a few trucks the last 60+ years and never knew about the solid front mount before.
