Head stud threads I have read on this forum that the threads in the block for the head studs are different than standard course threads and you should not clean them up with a standard tap, so how do you clean them up?
Re: Head stud threads Get a stainless gun cleaning brush of the correct size, probably a 38 cal. And use it in your drill.
Re: Head stud threads Get a whole set, and look over the selection of other sizes and adaptors! Gun brushes are extremely useful on old cars. You can easily get sizes made for guns from .177 to .50 (what ARE those guys shooting with .50??!?), and they will get out crud that othere tools have trouble dislodging.
Re: Head stud threads Heck - I just love my Browning 0.5" HMG mounted on the back of my 'technical'.
Re: Head stud threads Quote:
Re: Head stud threads Shooting a .50 cal. Thompson Black Diamond inline muzzle loadrer. So having them on hand is manditory anyway. The current black powder and pyrodex makes keeping it clean a real pain at times. Rod
Desert Eagle .50 Cal- + Same smoke pole you have + the Thomson PA hunter flint lock- I use a Nylon Brush then Brass Brush on the Guns. I have most caliber sizes avail- but would the prefered brush be the nylon or brass for the threads in the car? |
Re: Head stud threads there are also thread chaser kits available. I got a nice one from Sears. It is true that a tap or die are not good to chase threads.
