The Ford Barn
-   -   1936 headlight switch (https://www.fordbarn.com/forum/showthread.php?t=47027)
chrismac52 09-07-2011 08:43 PM
My lights work great except when I turn to the low beam setting, it immediately blows the fuse. How do the lights connect to the switch? I don't see where it enters the column.
JM 35 Sedan 09-07-2011 09:19 PM
Re: 1936 headlight switch
If it's the original setup there is a metal can at the bottom of the steering box that contains the light switch and horn contacts. All the wires to the lights and horn exit that can and travel forward. There is probably a wire between that switch and the low beam bulbs that is touching ground or maybe it's shorted to another wire.
chrismac52 09-10-2011 05:57 PM
What I have found is that if I remove the can and connect it back the lights will work correctly and then it will start blowing the fuse again...makes me think something is wrong in the can. Is that part replaceable? I found a replacement headlight harness, but it doesn't look the same and not sure if it would work out...this is the harness:
http://lbcunited.com/earlyford2/prod...23e30fdba5fa62
Thoughts? Right now it is working again after removing and putting the can back on, but I am guessing it will start blowing the fuse again as that has happened before.
Thanks in advance!
Lawson Cox 09-10-2011 07:58 PM
If it happens again I think I would buy a new wiring harness. Much cheaper than a fire. I recommend Tyree Harris's wiring harnesses. Great product from a super nice fellow.
Chris Nelson 09-11-2011 11:27 AM
I think Lawson is right. If it is original wiring on the car, it is probably so stiff and the insulation is crumbly that it would not be surprising if there were shorts. You would need to get a new wiring harness. If the rest of the wiring is similar, you probably need to change it all out or you will be fighting the same problem later in other parts of the car.
Mac VP 09-11-2011 11:47 AM
If the wiring is old, I highly recommend replacing it ALL. I also recommend using one of the battery disconnect switches on your battery. It won't save you if there is a major short while you are driving, but it helps with peace of mind when your car is parked.
Mike in AZ 09-11-2011 12:35 PM
if your wiring harness in that "can" doesn't look like the one in the ad, probably an excellent idea to replace your wiring....good luck.....Mike
Pompeyboy11 03-14-2025 09:57 PM
I have an issue with the lights on my 36 ford sedan, sometimes I find after cruising the lights are on, no matter what i do with the switch on steering wheel they will not switch off, I had this issue at a show where the park light was on. If I disconnect the battery then reconnect they are off. I have a batt disconnect terminal now. Any pics of where the light switch is housed and what it looks like would help. Any advice? I am in Australia, car is RHD.
rotorwrench 03-15-2025 12:44 PM
Don't be afraid to start a new thread for your questions. Ford used the switch on the bottom of the steering shaft at the steering gear case from 1927 clear up through 1939. and all the switches are similar in design. I think the right hand drive cars still used the same switch but I'm not positive on the later V8 cars. Ford started using a pull type switch on the dash in 1940 but yours has the control on the steering wheel just like the LHD types. The spider at the bottom may have problems or the switch may have problems. The control rod runs down inside the steering shaft to the bottom and then the spider connects the rod to the switch. The horn connection is between the bottom of the rod and the switch plate in the light switch housing.
