The Ford Barn
-   -   Head Stud Leakage ??? (https://www.fordbarn.com/forum/showthread.php?t=45511)
CC33 08-22-2011 07:48 AM
Will adding washers to the nuts on the studs help prevent coolant leakage? Were they originally set up this way?
wga 08-22-2011 07:55 AM
Re: Head Stud Leakage ???
Use thread sealer on the studs. Washers (hard steel type) provide a smooth surface for the nuts to bear against. This prevents galling, especially on aluminum heads.
Permatex non hardening thread sealer is great stuff. Best Gasket composite gasket.
Torque to spec incrementally, and retorque a couple of times.
ford38v8 08-22-2011 08:47 PM
CC33, Aluminum heads were originally fitted with washers. Cast iron heads were not. Cooland leakage at the top of the head is a sign that the studs were not sealed initially when installed. Kinda almost not gonna happen to try to seal them after the fact.
Walt Dupont--Me. 08-22-2011 09:18 PM
It's not new for the 48 and older engine with head nuts to have a few leak after a new rebuild. They usually seal themself in a few days. If you a couple that won't seal, remove the nut and smear some black RTV on the stud threads and retorque, they'll be fine. Walt
frenchy dehoux 08-22-2011 10:15 PM
I usually put on a light coat of sealer on the thread before installing them onto the block and also a small amount under the washer as well. Especially the studs that will be in line with the water jacket area I have not seen any leaks doing it this way.
Frenchy
