The Ford Barn
-   -   Restoration Qs...Very early rear end (https://www.fordbarn.com/forum/showthread.php?t=42515)
d.j. moordigian 07-18-2011 09:23 AM
Just took apart a ve-28 rearend. On the torque tube( it's the first one described in the
2011 revision, page 4-11 ) is stamped " A 869 ". It runs inline with the drive shaft. The
characters are " A" = 1/4" , numbers = 3/16" , which spooks me a bit, you would think
they would be the same size. Any thoughts?
Dudley
Mitch 07-18-2011 09:34 AM
Re: Restoration Qs...Very early rear end
Look down the page to Dean from Bozeman's stamping on A495 engine block.
Fred 07-18-2011 10:32 AM
That would be correct, But I did not know they stamped the tube @ the factory ??..
Gary Karr 07-18-2011 10:36 AM
I've never heard of or seen a number stamped on a torque tube. I'll have to look at mine on A 3261.
Ron in Quincy 07-18-2011 01:45 PM
The Drive Shaft Housing on A1276 (Light Delivery) has 3 steps behind the bell, and the taper is different than shown in the earlier Judging Standards, prior to being revised; it is also stamped near the bell with the A1040 number. The other thing I found different is the Rear Axel Housings, they have sleeves pressed on the housing ends. The axel nut does not have a washer and seats on the drum .
If you look at the drawing of the rear end in the earliest owners manuel you can see the 3 steps behind the bell and also see the axel nut with no washer.
Also,In the February 1928 issue of "Ford Dealer and Service Field" page 20-21, there is a article by Murray Fahnestock, Technical Editor; the article gives the mechinical details of the New Ford Rear Axel; its states " Hardened and ground sleeves are pressed on the outside ends of the axel housings, and the Hyatt type roller bearings which carry the wheels are mounted directly on these steel sleeves, thus making a simple and easily serviced construction "
When I find my to scale drawing of my drive shaft housing I will provide the actual measurements.
Ron
Behind bell the measurements are as follows:
1. 2" length by 2-9/16" diameter
2. 2-1/2" lemgth by 2-9/32" diameter
3. 7" length by 1-29/32" diameter
4. 13" length tapering from 1-29/32" to 2-7/8"
5. 2-7/8" diameter to end
Total length from front of bell to flang forging is 501/4"
Ron
Steve Ciccalone 07-18-2011 01:52 PM
I have six early tubes and none of them are stamped including A189's. Engine A869 went to assembly on December 1, 1927. I'm going to guess that there could have been a mechanical issue that may have resulted in the rear end being pulled and it was stamped so it would be returned to the appropriate vehicle.
Benson 07-18-2011 02:38 PM
2 Attachment(s)
I can not help with number stamping but here are some pictures of an early differential drive shaft problem.
Steve Becker said that this is fairly common and the design was changed early on to fix it.
This is a weak point in the early drive shaft design. The crack can be seen extending 2-3 key-way widths out to the right of the key-way and for the length of the key-way.
Dudley if you need more details I can send a higher resolution picture.
Ron in Quincy 07-18-2011 02:47 PM
I have added additional information to my post and corrected the number stamped on my deive shaft housing.
Ron
d.j. moordigian 07-18-2011 03:36 PM
Steve,
That was my thought when I saw the numbers.
Ron,
1, 2" length X 2 7/16"
2. 2.5" " X 2.275"
3. 6 3/4" X 1 29/32"
4. 10" taper to 2.910 (2 29/32")
5. I got 50 5/8", bell to bolt seat and/or 51" overall.
The numbering is interesting, I have one more ve-28 rear to look up.
Gary Karr 07-18-2011 06:45 PM
Ron, My VE-28 axle housings (A 3261) are also sleeved. I didn't think much about them when I re-sleeved them until you and I had a conversation about them. I'll have to check the torque tube.
d.j. moordigian 07-19-2011 09:36 AM
Checked another early rear end at home last night. It has Ford script springs, no
washers on the hub nuts, has brackets on the radius rods for the brake return
springs and the torque tube like the ones Ron and I have. I don't know about
the hub sleeves, brakes an hubs are still on the R.E.
Here is the kicker, the torque tube is stamped(same place).." 865 ".., No "A" that
I could see.
Ron, maybe a California thing?
Dudley
Charles Reese 07-19-2011 10:54 AM
1 Attachment(s)
can't help with the "why" but are 2 more!
d.j. moordigian 07-19-2011 11:02 AM
Charles,
My video card is bad in my computer, it's like looking in a fog bank. I can't make
out the top numbers!
I know your car is SFA, I wonder if Ron's is also?
Ron in Quincy 07-19-2011 12:58 PM
If my information is correct, A1276 Cowl Assembly was from the Rouge Plant and sent to the Kentucky Wagon Mfg. Co. in Louisville, KY. where their body and rear fenders were installed; ended up being shipped via railroad; it arrived in Oroville, Ca via a Western Pacific Railroad flat car with four (4) other Model A's, supposdly the first A's delivered to the Ford Dealer in Oroville.
Ron
Tom Wesenberg 07-19-2011 01:34 PM
Originally Posted by d.j. moordigian (Post 241566)
Charles,
A2628 is what I see in the top picture.
Charles Reese 07-19-2011 02:46 PM
A2628 ... these are extra tubes (4 sale is anyone is interested), not the one on my truck ... am at work so dont have access to see what if any # are on my early tube
Rich in Tucson 07-26-2011 06:22 PM
1 Attachment(s)
Here is another, number only (459), no preceding A:
d.j. moordigian 07-26-2011 07:17 PM
Rich,
I'm assuming its the same style torque tube as the ones above? I found another
this weekend,..1877.. Thank you
Rich in Tucson 07-27-2011 01:36 PM
Yes D.J., it is an early 1928 torque tube.
Gary Karr 07-28-2011 12:17 AM
I checked my torque tube and it is stamped A 1298. So, what are these numbers all about? Were these stamped with the same as the serial number of the cars?
