The Ford Barn
-   -   Windshield Swing Arm Assembly 1929 (https://www.fordbarn.com/forum/showthread.php?t=41757)
Hunter 07-10-2011 09:02 AM
I'm confused about the proper assembly of the fasteners associated with the windshield swing arm.
First the swing arm pivot bolt and nut. From the inside of the car was it screw, arm, lock washer, sleeve nut? Was a spring washer used? If so where was it located in sequence? Were all of these components nickel plated (29 coupe)? or was the spring washer if used blued?
At the windshield pillar it is flat washer, arm, rubber washer and cup, spring washer, and nut. All nickel plated except blued spring washer?
Thank you - Hunter
Steve Plucker 07-10-2011 09:44 AM
Re: Windshield Swing Arm Assembly 1929
Thank you - Hunter
Correct, according to the MARC/MAFCA RG's and JS (Revised 1994)
Pluck
Hunter 07-10-2011 07:36 PM
Steve - Thanks
Does anyone know the sequence for the swing arm pivot bolt/screw (first question).
Thanks - Hunter
Hunter 07-11-2011 08:18 PM
Ttt
