The Ford Barn
-   -   front end (https://www.fordbarn.com/forum/showthread.php?t=40718)
Mike 06-27-2011 09:49 AM
front end
Good morning,
I am working on a early 1928 Model "A" I noticed the pitman arm ball is bolted onto the pitman arm? Also the right steering arm ball is bolted on, I never have seen this before is it a early 28 part or repro??
thank you,
mike
1928Pickuppain 06-27-2011 11:14 AM
Re: front end
Sounds like a back woods repair job. I beleve all were origonaly forged solid.
Larry Seemann 06-27-2011 11:30 AM
Re: front end
In later Fords, don't know what years, these items had replaceable balls on a tapered shaft with a nut and cotter pin such as you describe. You can buy these ball/studs at vendors that sell early V8 parts. Probably a prior owner replaced them with these more "modern" parts when the balls wore flat.
Steve Plucker 06-27-2011 12:35 PM
Re: front end
Originally Posted by Mike (Post 229952)
Good morning,
thank you,
mike
I agree with the posts above. All the steering arms and pitman arms that I have ever seen were forged as one unit.
I would call A and L and buy you all three for your vehicle. Check the RG's out for correct ones.
A and L is listed in the STICKY above.
Pluck
Mike 06-28-2011 08:32 AM
Re: front end
thank you for all the info
mike
