The Ford Barn
-   -   New product Model A Driveshaft extractor (https://www.fordbarn.com/forum/showthread.php?t=38513)
DICK SPADARO 05-31-2011 08:17 PM
1 Attachment(s)
Thread topic should read Model B, sorry cant edit it. But it got your attention.
I dont frequetly post on the A section of the "Barn" but I thought you guys might be interested in this and as a heads up on some new stuff I have been fooling with to make servicing your car easier.
Every once in awhile you need a special tool to do some odd ball job.
If you have had to separate the drive shaft from the banjo pinion on a Model B you know that this is a pain, I hope this tool makes the job easier.
This is a billet machined collar that grabs the neck of the driveshaft and functions as a puller. After removing the driveshaft retaining nut and evenly expanding the tension bolts to the banjo the driveshaft just pops right out.
If you want more info you can just call or send a PM, I'm doing the instruction sheet now and will have product ready to ship 6/6. DS
