Model A Engine w/ 5 bearing cam? I'm an Early Ford V-8 guy...but I need some Model A help. What can you tell me about an early '28 block with a 5 bearing cam? Are they desirable? We just got one with some early V-8 parts...
The block looks good. No visible cracks or repairs in the block and it's only bored .015 over. Let me know what you think. Thanks, Neal |
Re: Model A Engine w/ 5 bearing cam? sounds like a good block to build a stock engine with. Some guys like the 5 main cam because they can use stiffer valve springs and have no cam flex. But, OTOH, the early blocks have weaker rear main bosses than the later blocks.
Re: Model A Engine w/ 5 bearing cam? You don't want one of those old 5-bearing Muddle A blocks. I'll give you $35 for it, including shipping to Portland, just to help you get it out of your way.
Re: Model A Engine w/ 5 bearing cam? Quote:
Re: Model A Engine w/ 5 bearing cam? ....with the block number, to the right guy, who knows.
Re: Model A Engine w/ 5 bearing cam? Since the answers seem to circle the intent of the question, I'll take a stab at it. The bottom line is there is no special value except to "the right guy" like most things. The percentage of folks looking specifically for that type block is small and likely very close to percentage of available blocks being that type.
Re: Model A Engine w/ 5 bearing cam? The above answers are all good. As a side note the cam could be worth something as the Donovan engine uses that cam. Ford made 3 versions of the 5 bearing cam, the first had all 5 bearings ground to the same size, this is the one Donovan uses. As the 5 bearing blocks were used up, the next version had all 5 ground, but the 2 intermediate ones were smaller, in the 3rd version those bearings were just rough-turned on a lathe. The smaller bearings allowed quicker installation into the block.
Re: Model A Engine w/ 5 bearing cam? Thanks for the info. I'll take a look at the cam and see what condition it is in.
Thanks again, Neal |
Re: Model A Engine w/ 5 bearing cam? Does the block have a number? If not, where is the number pad and what size is it? If it is/was a three or four digit # it is worth more than $35. I have three 3 digit cars and two 4 digit cars. I'm one of those guys Marco was referring to.
Re: Model A Engine w/ 5 bearing cam? It's a 170,000 number...which is June of '28 I think.
Re: Model A Engine w/ 5 bearing cam? Interesting. I have one where the oil line is drilled from the timing gear chamber, not a tube that was added later. The hole at the timing gear end is closed with a flat head screw.
clem |
Re: Model A Engine w/ 5 bearing cam? Interesting that an engine that late is 5 main. Will have to look at some of my later blocks. Thank you for responding.
This is from my engine block data... 5 OR 3 CAMSHAFT BEARINGS 5 # 481,204 OCTOBER 03, 1928 3 # 492,408 OCTOBER 06, 1928 (11,204) (SEE FORD SERVICE BULLETIN: JANUARY, 1929) (CONTINUED THROUGH END OF PRODUCTION) THE “RELEASE” INFORMATION OF SEPTEMBER 28, 1928, INDICATED: · “REMOVED SECOND AND FOURTH CAMSHAFT BEARINGS”. Pluck |
Re: Model A Engine w/ 5 bearing cam? Hi Neil, I believe we have the same engine. I just posted yesterday Barn Find. Take a look, https://www.fordbarn.com/forum/showthread.php?t=36596
Re: Model A Engine w/ 5 bearing cam? I think posting the block number, or partial number, of any block for sale or inquiry
is a good deal. It helps the people trying to ID the block and/or the anal group, that would be me, looking for the block from their chassis. Yes, it is a needle in a hay stack, but I care. Thanks again Neal. Looking for block#...A 352,XXX... |
3 cam bearings.. |
Re: Model A Engine w/ 5 bearing cam? Later blocks made in 1931 have stiffeners added to the rear transverse web making them stronger. Also, later blocks have better coolant flow.
Although the 5-bearing cam has a better load distribution than the later 3-bearing cams, the 5-bearing supports were not necessary. The maximum cam bending moment is reacted by the center support where the oil pump & distributor drive gear is situated. By the way, camshaft thrust loads are reacted by a spring loaded plunger in the front timing gear cover of the engine. The thrust loads come primarily from the torque of the oil pump & distributor drive mechanism. |
Re: Model A Engine w/ 5 bearing cam? My 1928 Sport Coupe 10-8-28 has the 5 main cam and block. All 5 bearings are to size on the cam and in the block. This is the original engine it has the solid front engine mount, and equalizing brakes. I have the title from 1938. all numbers match.
