Steering wheel & shaft taper ? What’s the taper size or number for the sheering shaft on a 39 truck. I got a banjo steering wheel from a 39 car but it won’t fit the taper is different. I need to buy a tapered reamer and “fit” this steering wheel.
Re: Steering wheel & shaft taper ? From my experience, The model A shaft and taper is bigger, but 32 until they went to splines they are all the same. No idea when that occurred
Re: Steering wheel & shaft taper ? Curious if it's the same 7 degree taper as spindles to keep machining and tooling down or consistent while on the line. Hopefully someone knows for sure.
Re: Steering wheel & shaft taper ? Real TRKs shafts are larger than cars, I remember. Newc
Re: Steering wheel & shaft taper ? It's a 5 degree taper. Some heavier trucks use a bigger diameter.
Re: Steering wheel & shaft taper ? Quote:
Re: Steering wheel & shaft taper ? It sounds like you have all the information to calculate the taper, you just need someone to do the trigonometry for you.
Re: Steering wheel & shaft taper ? I thought I would ask on here and save some guess work. A reamer that size is a bit spendy so I wanted to be sure before I order one. Looks like I will visit some machine shops with both steering wheels and see if someone has a reamer or a way of cutting the required taper.
Re: Steering wheel & shaft taper ? Someone with a lathe , an off set tail stock and some cutting , hardening should be able to rig up a home made cutter .
Re: Steering wheel & shaft taper ? I think originally that taper on the shaft was rolled in so the thickness of material does not change. To ream a hole with a keyway in it would be very hard to do and have a nice result. I have made shims to put a bigger wheel on small shaft, A onto a v8 shaft for example, but both were tapered the same. Not sure how to go about your dillema
Re: Steering wheel & shaft taper ? Cas3 good point !
Re: Steering wheel & shaft taper ? I think the OP wants to re-ream the steering wheel and keep the shaft the same, no?
Re: Steering wheel & shaft taper ? I just had the wild idea that one might be able to use valve lapping compound and lap the wheel to the shaft. Might take forever, tho. Use a nut and a washer to keep the wheel square with the shaft if threads are showing. Could work, but you'd still need to file the keyway to fit a key.
Al Hook |
Re: Steering wheel & shaft taper ? IF you have a set of caliper OR a set of micrometer's you can figure out the taper pretty easy
https://www.youtube.com/watch?v=WRN4an7YGA8 Than you can "possibly" find a taper reamer that matches. |
Re: Steering wheel & shaft taper ? delete.
Re: Steering wheel & shaft taper ? It should fit, or it should be loose and fit with a shim.
If it doesn't someone has changed something or the parts are not what you think they are. Ford steering wheels had the same tapers from 32 to 48. 47 in trucks. I'm talking cars and pickups. Why not post some pics of what you have and what the problem appears to be. Do you have any other steering wheels that could be tried on? Something is not adding up here. Mart. |
Re: Steering wheel & shaft taper ? The keyway in the steering wheel probably won't deep enough after the hole is made bigger.
Re: Steering wheel & shaft taper ? you need, big lathe, 4 jaw chuck as the wheel probably won't center on a 3 jaw, small boring bar run off compound at proper degree which is ?, then file the key way to fit when done.
Re: Steering wheel & shaft taper ? 1 Attachment(s)
Both ford factory wheels Best I can do with pictures. The truck wheel has a socket sitting in it. That socket won’t fit in the car wheel |
