The Ford Barn
-   -   Quick change gear set (https://www.fordbarn.com/forum/showthread.php?t=351266)
Chris Haynes 08-06-2025 11:15 AM
I am in the process of installing a Halibrand 101 on my '30 Tudor. I know for street use a 12/12 set of gears is direct drive as in the original. What would be the best set to use during hill climb?
Hitman 08-06-2025 12:48 PM
Re: Quick change gear set
Depends on a lot of factors. You'll find that most people have a couple of gear sets for different hills.
How long is the hill? What grade? What altitude is the event at? What rpm do you want to be at, at the top of the hill? What gear do you want to be in at the top of the hill? Will you drive the car home after the event with the hillclimb gear set?
Lots of details.
nkaminar 08-06-2025 02:09 PM
Use the practice runs to find out which gear ratio gets you top in the fastest time.
Jim Brierley 08-06-2025 02:14 PM
Chris, All cars are not the same! I have trouble shifting from 1st to 2nd, so use a 6.40:1 final drive and tart in 2nd gear. I also use a 3.05 for highway driving. If you can borrow gears, do so and see what you like.
Jim Brierley 08-06-2025 02:17 PM
You may find that the radius arms don't line up with the torque tube, reverse the arms right to left and it should be fine.
