The Ford Barn
-   -   Fun Projects regulator (https://www.fordbarn.com/forum/showthread.php?t=351195)
eagle 08-02-2025 10:19 PM
I put a new tractor 6V battery from Fleet Farm and a Fun Projects voltage regulator 14 years ago last spring. Both are still going strong. I know they had quit building the FP regulator, I haven't kept up, are they back on the market yet? I don't use a battery maintainer, just jump in and start it in the spring, shut it off for the last time in the fall. Store my A in an unheated shed. So, I consider that to be a true testament to the FP regulator and Fleet Farm batteries.
alexiskai 08-02-2025 10:54 PM
Re: Fun Projects regulator
The EVRs on the market today get installed in the generator rather than the cutout.
Bruce of MN 08-03-2025 04:13 AM
I wonder what the latest is on this type?
https://www.fordbarn.com/forum/showthread.php?p=2297785
ndnchf 08-03-2025 06:18 AM
2 Attachment(s)
Mike Hill's EVR is currently available for both long generators and Powerhouses. I've installed about a dozen of them, including in my own cars. They work perfectly.
Steve
nkaminar 08-03-2025 09:16 AM
You will not find any generators with third brush regulation on any cars made after the Model A. (Maybe one or two.) The voltage regulator will make the battery last a long time. Back in the day we would get a voltage regulator from a more modern Ford and adopt it to our Model A's.
Henry's aversion to any electrical mechanisms may have been why the Model A had a generator with third brush regulation. It may also be why the Model T had such an antique ignition system up until the very end.
SDJason 08-03-2025 10:39 AM
From that thread, here is a link directly to his website where he discusses the development of his Fun Projects type replacement regulator, and from there you can go shopping (for both Model A & Model T).
Edit: took a look at his website, looks like the Model A regulator is out of stock, with no backorder option : (
alexiskai 08-03-2025 11:04 AM
I was talking to rackops recently about the potential for a really cool accessory. It would be a battery housed in a replica original case, but instead of lead-acid it would be LiFePO4 cells. These have much higher energy density than lead-acid, so the cells would take up less than half the case. Then in the rest of the case you could put a circuit board that would intelligently charge the cells, including a voltage regulator. That way you could just use a stock generator.
It would also be user-serviceable, so if the cells wear out you could swap in new ones. And it would only weigh about 20 lbs.
Six 38120S cells configured as 2s3p would get you 6.4V with 30Ah capacity and 300 cranking amps, with the ability to absorb the full 20A output of the generator.
nkaminar 08-03-2025 12:26 PM
If you have a 12 volt car you can buy a Li-ion battery on Amazon starting at about $140. These batteries have amazing cold cranking amperage. I think there are 6 volt Li-ion batteries too.
alexiskai 08-03-2025 12:43 PM
There are 6V LiFePO4 batteries but they're built to run golf carts, they don't have the cranking amps a Model A would need.
nkaminar 08-03-2025 01:50 PM
Here is a 6 volt Li-ion battery with 680 cold crank amps.
https://www.wholesalebatteries.net/p...-6-12-warranty
alexiskai 08-03-2025 02:59 PM
Pricey, though, wouldn’t sell to this market.
Lawrie 08-03-2025 03:24 PM
my 33 and 34 have 3 brush generators .
Lawrie
CWPASADENA 08-03-2025 09:47 PM
It was not until the later '30s that ford went to a 2-brush generator.
30Tudor 08-03-2025 10:35 PM
There are a couple of challenges with the cutout style EVR:
* the recommended third brush setting is 5 Amps which limits the generator output
* the cutout style EVR is highly susceptible to damage if there is a high reverse current put through it (eg. polarizing the generator)
The "Tom Wesenberg (TW) Style EVR", similar to mine, does not have these limitations. Further, if the generator is disconnected from the battery, this EVR will protect the generator. The TW style regulates the current to the field coils to vary output voltage to 7.1V similar to the early Ford electromechanical voltage regulator (steady car ammeter reading). The Cutout style "shorts" the excess current to ground once the generator output exceeds 7.1V thereby cycling the battery charge rate (varying car ammeter reading).
My understanding is that Jeff Stevenson (modeltstarters.com) is no longer pursuing a cutout style voltage regulator for the Model A. ...according to a mutual friend that was testing one.
Badpuppy 08-04-2025 07:39 AM
That's an AGM battery, like the Optima.
eagle 08-05-2025 07:23 PM
I set my generator output to 16 amps at fast idle with the stock cutout, which was nearly max on my generator. Then installed the regulator-in-the-cutout. It charges +1 amp with lights on low, -2 amps with lights on high. Std bulbs. After starting, the current jumps to 10 or 12 amps, then tapers off as the battery rises. Been flawless for 14 years, battery still cranks well. The directions I got with mine said to set at 16 amps. It came from Mac's. The nice thing about the cutout regulator is the simplicity. Not sure what the advantage of a lithium or AGM battery would be, if you take care of a tractor battery they will last many years, and they're cheap... relatively. Getting close to $100
