The Ford Barn
-   -   Shift Tower trim (https://www.fordbarn.com/forum/showthread.php?t=351090)
ampico-kid 07-29-2025 04:07 PM
Shift Tower trim
Wasn't quite sure what to call this post, but what I'm looking for is some way to dress up the area around where the shift and the emergency brake handle come through the floor carpet. As you can see in the picture the opening in the carpet/rubber mat is starting to look pretty ragged. I'd like to dress it up a bit with something? But what? Is there any kind of a trim ring or something made to dress it up? Thanks.
https://i.postimg.cc/RFXyFxPV/20250729-163026.jpg
stevemclark 07-29-2025 04:33 PM
Re: Shift Tower trim
https://www.mikes-afordable.com/product/A7000EB.html. https://www.mikes-afordable.com/product/A7000BBSS.html. https://www.mikes-afordable.com/product/A7000GB.html. https://www.mikes-afordable.com/product/RAR207.html.. .From Mike's,other vendors carry similar parts.
Y-Blockhead 07-29-2025 04:36 PM
Most vendors sell a shift and parking brake boot.
https://www.snydersantiqueauto.com/p...d=978882&cat=0
https://www.snydersantiqueauto.com/p...d=978879&cat=0
They even have a S/S trim rings if you want to get fancy.
https://live.staticflickr.com/65535/...71b0e90c23.jpg
https://live.staticflickr.com/65535/...c5b4e08e9c.jpg
marty in Ohio 07-29-2025 05:21 PM
Was there any boot originally?
Marty
marty in Ohio 07-29-2025 05:24 PM
Another question, what models had carpeting in the front, in the back?
Marty
Gary WA 07-29-2025 07:08 PM
Marty
No boot originally
nkaminar 07-30-2025 10:09 AM
The boot for my parking brake handle was very difficult to get on and off. I slit it to make things easier.
Bob Bidonde 07-30-2025 10:09 AM
Only deluxe models have carpeting.
Y-Blockhead 07-30-2025 01:33 PM
Really? I put a little vaseline on it and it slid right in. :p
ampico-kid 07-30-2025 01:45 PM
Originally Posted by Gary WA (Post 2403214)
No boot originally
If there was no boot originally, how did they make the edging around the shift tower and the emergency brake look neat and trim?
ampico-kid 07-30-2025 01:50 PM
Originally Posted by Y-Blockhead (Post 2403180)
I've seen those "boots" for sale, but thought they looked kind of sloppy because the trim rings overlap each other. I guess if that's the only option, it looks better than seeing the edge of the carpet (and the rubber mat) unraveling.
Y-Blockhead 07-30-2025 01:56 PM
Although my rings appear to be overlapping in the picture, they are not. They sit flush. I trimmed the parking brake to fit the shifter ring.
Y-Blockhead 07-30-2025 01:58 PM
Although my rings appear to be overlapping in the picture, they are not. They sit flush. I trimmed the parking brake to fit the shifter ring. I imagine you could trim the shifter ring to fit the parking brake also, if that appeals more to you.
JayJay 07-30-2025 02:01 PM
My boots have a fold of rubber immediately above the flange that goes under the carpet, the fold hides the edge of the carpet. Sorry I can't show you a pic, I just took the carpet and floorboards out this morning!
I shoot a spritz of Armour-All on the inside of my e-brake boot to help it slide over the hande better. Standard silicone-base detailing spray works fine as well. Both dry nicely with time, unlike Vaseline.
BTW, a rubber boot for a VW bug or dune buggy works great for the 1/2" shaft on a Mitchell O/D. Matches the rubber boot for the shift lever well.
Jim Mason 07-30-2025 03:12 PM
1 Attachment(s)
From the RG&JS 160B
Jim Mason 07-30-2025 03:18 PM
In 1928 the tudor, coupe, sport coupe and leather back fordor had carpet also. See RG&JS for more information
ampico-kid 07-30-2025 05:46 PM
Originally Posted by Jim Mason (Post 2403378)
From the RG&JS 160B
Is this a picture of what it would have originally looked like from the factory? I have that, but with the passage of time the rubber gets hard and brittle and starts to break up around the openings. That's where I'm at now and looking for a solution. I'm not necessarily looking for a RG&JS solution, but rather one that does the job and looks decent.
Thanks for all of the replies.
Jim Mason 07-30-2025 06:31 PM
Remove the pyramid rubber. Bind the edge of the carpet. Replace the rubber with one that fits.
