Battery killed after 2 days New wiring harness. Battery takes a charge. Seems every 2 days battery is dead. What can cause this.
Re: Battery killed after 2 days Tap the top of the generator cutout with a small hammer or wrench to unstick the points. They may be stuck and are draining the battery.
Also ensure the brake light is off when leaving the car for the night. Marshall |
Re: Battery killed after 2 days Quote:
Re: Battery killed after 2 days Thanks everyone
Re: Battery killed after 2 days Battery may be kaput. How old is it? Freeze in the winter?
Re: Battery killed after 2 days A lot of Model A owners end up putting battery disconnect switches in their cars. It will save the battery and is a safety thing.
With the battery disconnected, use the ohm setting on your multimeter to see if there is a drain to ground. Disconnect one thing at a time to discover which item is causing the drain. Also what Jon Crane said. |
Re: Battery killed after 2 days Get into the habit of checking the ammeter after shutting off the engine. If the needle dips into the negative side and stays there when the ignition key is turned off, something is drawing current. Stuck cutout points usually take an hour or two to completely drain the battery, while a stuck brake light may take one or even two days to do the job. Although unlikely, if the instrument panel light is left on, it, too, will eventually drain the battery. Those lights are not real bright, so if you only drive your Model A during the day, you might not even notice that the light had been inadvertently turned and left on.
Marshall |
Re: Battery killed after 2 days Has this only happened since you put the new harness in?
I mounted this one in our Coupe. It's through the wood floor board (flush with the wood). I just lift the mat to turn it on or off. The connector for my Battery Tender is right next to it. https://www.summitracing.com/parts/sum-g1442 |
Re: Battery killed after 2 days I had a slow drain, turned out to be a misbehaving "Pop - Out" ignition switch. Pushed in OK but saw still "on" . Drain was elusive because of position of breaker points. A turn- around to MR Crabtree for a rebuild solved the problem
Joe B |
