light operating handle I just changed my coupe steering column over to a f100 . Trouble now is when i turn wheel the lights come on.Also the cowl lights usually are down to the left. Now they are top left.,,say eleven oclock and to turn lights on you keep moving downward. What to do. Im beat. Appreciate all the help and suggestions i can get RAY
Re: light operating handle Quote:
Also it sounds like you may have the spider in the incorrect position. The new spiders are junk. They are stamped and the clip does not fit like an original (black one). https://live.staticflickr.com/65535/...4541e7231c.jpg |
Re: light operating handle It could also be that the horn/light switch rod is bent and binding in the steering column. How easy is it to turn the switch on or off with the steering wheel not moving?
Re: light operating handle If the F-100 box came from Randy it should have a new light rod included.
Re: light operating handle I didn't get a new switch rod with my F 1 box from Randy.My friend didn't either.We bought then 6-7 years ago.Is that something new?
Re: light operating handle I have installed six F1`s from Randy and never ordered them with the horn rod. the reproduction horn rods are a little bigger OD
you need to make sure the horn rod is Not bent. also, the top of the horn rod can rub inside the steering wheel. |
Re: light operating handle I indeed did get it from Randy but it did not come with a new rod. I spoke with him today and he touched on the fact of the bushing at the top of the tube the wheel fits on. so it back to the job of taking the spider off and putting in the bushing .Also the wheel will hit the handle when i turn the wheel so i guess its a missing bushing Thanks to all of you guys i am headed to a successful job. FORD BARN is the best TNX RAY
Re: light operating handle We only provide a light / horn rod on our 7 tooth conversions. The original one is not the right length for the conversion. We also provide them when a customer is missing one or needs a new one. Randy
