Oil Pan I have my engine out and am trying to get the oil pan off. I have all bolts out, but an old wood chisel isn't working and hammering on an oak board on the pan edge the same. My next step is to use my engine stand to make it more stable and pound on it harder. I maybe used Hylomar on the gasket in 2020 and it worked too well.
Any suggestions to get the pan off? I'll recheck the pan bolts. |
Re: Oil Pan Double check to make sure that all the bolts are out.
Re: Oil Pan 20 pan bolts and the 3 for the sheetmetal cover on the flywheel housing and you should be good to remove
Re: Oil Pan I have had good luck using acetone to dissolve Hylomar. Wipe some along the edges of the oil pan and let it sit for a day.
Re: Oil Pan Quote:
Re: Oil Pan Stiff bladed putty knife sharpened up on the bench grinder. Use a hammer to tap it in between the pan and block to cut the bond.
Re: Oil Pan This tool works great.
https://www.oreillyauto.com/detail/c...tor/lis0/50210 You can shop around for it by the Lisle tool number 50210. |
Re: Oil Pan Quote:
Re: Oil Pan Thanks to all for the tips. I ended up hammering in a thin putty knife and the pan came off easily. The price I paid for fewer drips!
