The Ford Barn
-   -   Coolant Puddle (https://www.fordbarn.com/forum/showthread.php?t=350774)
spinelll 07-16-2025 06:21 AM
Coolant Puddle
1 Attachment(s)
Damn. I noticed this puddle of coolant on my timing gear cover. It was much deeper a few days ago.
My thoughts on debugging are: Water pump packing, Water pump gasket, head gasket.
Is that a sound approach?
Thanks
Leo
nkaminar 07-16-2025 06:27 AM
Re: Coolant Puddle
Take some toilet paper and dab it on the suspected locations. It will soak up any dampness to reveal where the leak is coming from.
Big hammer 07-16-2025 07:07 AM
Re: Coolant Puddle
I use my blue paper shop towel, when it turns a darker blue, bingo ! Last year I was under my A and heard a drip drip, what the heck, upper radiator hose was leaking. First time finding a coolant leak by hear :-)
CT Jack 07-16-2025 07:23 AM
Re: Coolant Puddle
Most likely it's your pump that is leaking. Usually head gasket leaks appear somewhere in the midsection region of the head. Rebuild the pump with new gaskets and seals or install a leakless pump. Also, make sure you replace the fan with an aluminum replacement.
BButturff 07-16-2025 07:58 AM
Re: Coolant Puddle
First, check to see if it's leaking from either of the two upper radiator hose clamps. It's common and could save you from troubleshooting all the other areas that might be leaking.
KMBeers 07-16-2025 03:05 PM
Re: Coolant Puddle
When I had a leak that was collecting on the top of the timing cover I used a black light and there was enough fluorescence in the antifreeze that it showed the upper hose clamp leaking. As BButturff said I would look there first because might keep you from troubleshooting all the other areas that might be leaking.
Bruce_MO 07-16-2025 09:49 PM
Re: Coolant Puddle
I agree on upper hose clamps; mine leak especially during cold weather. Can’t seem to get the clamps tight enough without distorting them
BButturff 07-17-2025 08:18 AM
Re: Coolant Puddle
In my experience there are a couple of solutions to the leaking upper hose. I've found that as the hoses age they get hard (less flexible) and can be difficult to get to seal. The original clamps seem to add to the problem by pinching the hose as they're tightened. Even modern worm gear style clamps, while better, don't seal well especially when cold. Replacing the hose with a new one along with new clamps will fix the problem in most cases. Sometimes you can use the modern worm gear clamps for a while and then replace them with original style clamps once the hose is "seated". Or, if your Model A is a driver and you're not concerned with the original look, you can use a wider even more modern T-bolt full circle hose clamp that will seal even older hoses with ease. They're available at performance auto stores and Amazon. https://www.amazon.com/dp/B0B87RYQJ1...n_title_3&th=1
https://www.fordbarn.com/forum/data:...AASUVORK5CYII=
Benson 07-19-2025 05:47 AM
Re: Coolant Puddle ---- from water pump leak
Tighten packing nut
Attachment Link will not post ... deleted.
Marshall V. Daut 07-19-2025 08:49 AM
Re: Coolant Puddle
I once ordered a very expensive double sealed water pump from a well-known private vendor. It leaked from Day One exactly where your leak apparently originates. No amount of hose clamp tightening or even hose replacement solved the problem. Because it was double-sealed, the packing nut was purely cosmetic and tightening it would have no effect. Nothing worked: drip, drip, drip. Finally, I removed the water pump and examined the casting. It was cracked on the bottom of the mating surface and had come to me that way! I don't know whether this was created by improper boring for sealed bearings or whether it was an original housing that had once frozen and had cracked. Very disappointing. That was the last water pump I ordered from this guy, as I had perceived a drop-off in quality in the last couple I had ordered from him for my cars and for customers.
Anyway, if tightening the clamps and replacing the upper hose don't help, run a bar of soap over the bottom portion of the pump housing where water in the cylinder head rushes past. If the leak temporarily stops, the housing is cracked. Try the other suggestions posted so far first, but keep a cracked housing in the back of your mind, should no recommendation work.
Marshall
katy 07-19-2025 09:20 AM
Re: Coolant Puddle
Originally Posted by Marshall V. Daut (Post 2401389)
But keep a cracked housing in the back of your mind, Marshall
Good idea for all of us.
