Correct fan for 34? I'm putting my 34 coupe together with 59a block,PM-7 and a 39 fan-mount generator.I have a Walker rad from Speedway and am wondering what is the proper depth fan/spacer for a stock setup.
Re: Correct fan for 34? Use a stock 4 blade 33/4 fan. The space between the fan and the flange that bolts to the generator is about 1 inch. The 35 and up is about 2 inches, which gets too close to the radiator.
As you know: you will have to re-route the upper rad hoses to accomade the 59A heads. This set up is simple and works and looks best. have fun |
Re: Correct fan for 34? Quote:
Charlie Stephens |
Re: Correct fan for 34? As posted above, the "hub" on the fan is about 1" wide for 33-36. That is about all there is room for on a 33-34 at least...
After you obtain the proper fan/hub, the next fun comes when you realize that the reproduction radiator (probably) does not have the "well" in the bottom rearward of the upper tank that is required for fan clearance, since the fan has to be up high enough for the blades to clear the distributor and coil which are directly below it. Depending on the intake manifold generator mount height (low vs high) there may be other problems??? Like alot of other things, I did learn all this the "hard way." |
Re: Correct fan for 34? Another bit of trivia. The '37 and up (for a couple of years) intake manifold places the generator lower than the earlier ones.
Charlie Stephens |
Charlie Stephens |
The 59A in my 32 pickup is mounted slightly higher than stock, so I had to trim the blades of my stock 32 fan. I just cut a pattern to match the profile of the stock blade, then slid it down on the blade, marked and cut, and carefully ground to the scribed line. You can't tell it has been trimmed, unless you measure it. Neal |
Re: Correct fan for 34? This will hurt.
#1 Do you still have an origional Radiator? If so: Have it recored with a modern core. #2 Can you get an upper tank from an orgional Rad? Have the "bubble" cut-into the Walker rad. Should you decide to modify the new Walker Rad. Check the angle of the top and bottom water outlets. Sometimes they need to be moved a little to line up with your engine outlets. |
Re: Correct fan for 34? Same situation here, 59 AB, Thickstun intake PM7 in a 34 coupe with alternatively 59AB generator or stock 34 generator available.
I wanted to install a 1940 Ford 6 blade heavy duty fan with a 1940 single groove crankshaft pulley in my 34 coupe, but reading this thread i would like to know if i will have a clearance problem with fan to rad ?. Q1: Can anyone who is familiar with this problem recommend a solution using the parts mentioned above? Q2: I have seen on pictures that some people are running the fan/pulley unit on their 59AB below the generator. I could use the 59AB stock generator and no worries about clearnace fan/radiator if somehow mounted below! How does that work? Regards Randolf |
Re: Correct fan for 34? Here's an eye-opening post on the Clubhotrod site. You'll see that the owner of the '34 Ford ordered a radiator and electric fan from Brassworks only to find out there isn't enough room to remove the distributor cap on the 59A engine with the shroud. I learned a lot by following the thread...especially about having to mount the fan to the generator and eliminate the front pulley on the crankshaft. Check it out.
http://www.clubhotrod.com/hot-rod-bu...e-hot-rod.html |
Re: Correct fan for 34? Aint it nice when some one changes everything under the hood and wonders why his fan dont fit anymore.ken ct.
Re: Correct fan for 34? As always Ken, very informative information. DD
